As seasoned data-travelers, we’re used to wielding the internet to send messages and communicate to others without any limitations. No one has to be stranded on a figurative island blowing smoke signals… unless of course they wanted to be. What [Harm Alexander Aldick] has done with his project “Lorem Ipsum”, is create a situation where others can only communicate to him through a sort of message in a bottle. The bottle in this case is an electronic widget.
In this social experiment, [Harm] has stationed a small Ikea picture frame at his desk, which shows images and text sent to him in real-time from others in the world. With an Arduino as the brain, a small 8×8 LED matrix mounted at the bottom right of the frame displays the data received by means of an ethernet module. Anyone can use his web interface to modify the pixels of the matrix on a virtual version of the installation. Once sent, the message is transmitted through an IPv6 internet connection and is translated to UDP which the unit is controlled by.
[Harm]’s project investigates how people react when given the chance to send a message in complete anonymity to someone they don’t know… in of all things, the form of something as limited as 64 pixels. The project name “Lorem Ipsum” refers to the filler text used in graphic design to hold the place of what would otherwise be more meaningful information, so that it doesn’t detract from the experience of viewing the layout. Curious about what sort of ‘graphical experience’ I would come up with myself, I took a shot at punching away at [Harm’s] GUI. I got momentarily lost in turning the little red dots on and off and eventually turned out this little ditty:
It was supposed to be something of a triangle, yet turned into a crop circle… or pronged nipple. After it was sent, I wondered whether or not [Harm] actually saw it. In the case that he did, I can only imagine what I communicated to our fellow hacker abroad with my squall of dots. All of these thoughts though are the whole point of the project. Awesome work!
