If you dabble in the ham radio hobby we’re sure you’ve heard of GPS position monitoring or tracking using APRS packet data commonly transmitting over the VHF ham band and FM modulated. One of the issues you’ll face using this common method is range limitations of VHF. [Mike Berg] a.k.a [N0QBH ] tipped us off to his latest project to greatly increase the range of a standalone APRS system utilizing the HF bands on single-sideband (SSB).
There are some unique challenges transmitting packet data using SSB over HF bands. High Frequency APRS has been around for decades utilizing FSK AX.25 packet transmissions at 300 baud, but it was quite susceptible to noise and propagation aberrations. More recently PSK-31 at the slower 31 baud speed helped alleviate many of these issues. [Mike] utilized the somewhat updated APRS with PSK-63 and the “APRS Messenger” program to overcome these challenges. [Mike’s] hardware solution consists of a PIC 16F690 micro which is coded to receive data from a GPS receiver, convert it into PSK-63 and then transmit on 30 meters over an attached HF radio. A second receiving station or stations at great distances can pick up and decode the transmission using the “APRS Messenger” program connected to the receiving radio over the computer’s soundcard. The program can then forward the tracking information, if good, to tracking websites like FindU.com and APRS.FI.
You can build your own FreeTrak63 by downloading [Mike’s] parts list, assembly code, HEX file, manual and schematic. The PCB is available on OSH Park if you don’t want to make your own or wire point-to-point. Let’s not forget to mention how hackable this hardware is, being really just an eight bit DAC, micro, serial in and radio out. One could reprogram this hardware to do other modulation schemes like AX.25 packet or MFSK16, the sky’s the limit. If short-distance on VHF with existing Internet linked receiver networks using an Arduino compatible platform is more to your taste, then checkout the Trackuino open source APRS Tracker.
