Styrofoam watercraft, PCB hydrofoil
A PCB Can Be A Hydrofoil, If It Really Wants To
You know those old cliche that the younger generations have begun to cynically despise: “follow your dreams!” “You can be anything you put your mind to!” — well, perhaps they are true on occasion. For instance when [rctestflight] had PCBs that dreamed of becoming a hydrofoil, he found a way to make that dream come true.
It’s kind of obvious in retrospect: printed circuit boards are made of FR4, which is a form of fiberglass, and you know what else is commonly made of fiberglass? Boats. So yes, the material is suited for this task. The fact that solder joints hold up to use in a little remote-control hydrofoil is less obvious, but good to know. It certainly makes for easier assembly for those of us who have developed an allergy to epoxy.
Ease of assembly wasn’t really the point here: the point was that by making the “mast” of the hydrofoil out of PCB– that’s the part that holds the underwater wing– [rctestflight] figured he could (shock!) print a circuit onto it. Specifically, a liquid-level sensor, and because microcontrollers are so cheap these days he went the “total overkill” route of embedding an ESP32 on each mast. He started with a resistive sensor, but since those self-corrode too quickly, the team switched to a capacitive sensor that doesn’t need to form a galvanic cell in salt water. Come to think of it, that might still be a problem with the solder joint between the PCBs. Good thing nobody will be riding this one.
Having such a sensor and brain close-coupled allows for a faster control loop than the sonar [rctestflight] had previously been using to control his hydrofoil’s altitude.. Pivoting each mast with its own servo made for a smooth flight over the water— well, once they got the PID tuning set, anyway. Check it out in the video embedded below.
We’ve seen PCB used for enclosures before, and even the chassis of a rover, but using it for a hydrofoil is a new hack. Continue reading “A PCB Can Be A Hydrofoil, If It Really Wants To”
SnowSled
Uber-Cheap FPV Snow Sled
Has the winter blues got you RC vehicle guys down? Well, cheer up! Spring is just around the corner. In the meantime though, you can take a page out of [BenNBuilds’] book and build an FPV Snow Sled.
So how is using this Snow Sled in the winter different from any other RC vehicle? [BenNBuilds] controls it from inside his house where he stays warm and toasty. The on-board FPV camera sends video back to a receiver in the house where it can be either displayed on an LCD screen or on FPV goggles. Plus, being able to see the sled from the window doesn’t hurt either when getting in a sticky situation!
The craft it self was made on the cheap from spare parts that were kicking around. The frame is made from foam board and is powered by a ducted electric fan. A rudder similar to that of a hovercraft or swamp boat provides the steering. Since [BenNBuilds’] transmitter had a couple extra channels, he hooked up a pan and tilt system for his FPV camera. Check out the video of this puppy in action after the break….
Continue reading “Uber-Cheap FPV Snow Sled”
3D Printed Hydrofoil Boat RC Flies
hydrofoil boat
[Wersy] has been trying out different designs for 3D printed RC boats — his latest is a hydrofoil!
He’s using a high power RC plane out-runner motor, which he found is simply… too powerful. It would cause his first boat to flip and sink if he opened the throttle up too much! To counter this — and make full use of his motor — he’s made new two boats; a hydrofoil, and a dual-hulled  air(?) boat.
He based the hydrofoil’s profile off of NACA 63-412, a typical profile for sailboat hydro foils like the Moth. What he found was it’s still extremely difficult to get the right balance between the pitch of the wings, and the throttle output to hit a steady condition for driving smoothly. It works, but it will still needs a few more iterations!
His other solution, a quasi-jet engine-dual-hulled-boat is pretty fun too — he’s 3D printed a large impeller for his motor, and strapped it in between two of his boats! It’s quite a bit more stable to drive, and looks pretty unique!
Stick around after the break to see both of them in action.
Continue reading “3D Printed Hydrofoil Boat RC Flies”
