Normally case mods are all show and no go, but [Fredrik Perman] and [Michael Stabile] took their old render farm and made it a working showcase for the front lobby. This is a perfect combination of function, beauty, and practicality. It is a great conversation piece, allows easy working access, and provides a tremendous space savings in one sweet looking wall-mounted case. The frame is aluminum, the back consists of sheets of polished diamond plate, with a clear acrylic sheet for a cover. The case sides are left open to allow the blue LED fans to circulate air. Cooling a render farm crammed in a closet can be quite difficult, but isn’t a problem with this open design. This build is also much prettier and maybe more manageable than the setup in ExtremeTech’s Build Your Own Render Farm article.
There are a few more pictures after the break.
