There’s just something so satisfying about industrial design from the years past. [Kenneth] found an old “portable” tube TV and decided to give it a little upgrade so he could keep it around the house.
It was a black and white Singer TV, with a whopping 6″ tube display. Using his trusty screwdriver set he took the whole thing apart, keeping only the frame and outer casing. Inside he jammed a 5″ LCD display, a Raspberry Pi and a power supply — with some room to spare. He also replaced the speakers with some upgraded baby woofers and an audio amp for the Pi.
The end result is a pretty snazzy little device capable of playing movies, games, or hypothetically, even as an all-in-one computer — but who actually uses a Raspberry Pi as their daily driver? Especially one with only a 5″ display…
But it’s a cutie, and sits nicely on the coffee table. For a larger retro TV rework, we’re quite partial to this conversion of a Philco TV (a sub-brand of Phillips) with a flat panel LCD.
[via r/Raspberry_Pi]
