[iskor12] put together a blu-ray laser that is waterproof and packs quite a punch. At 182 mW there is enough power here to pop dark colored balloons (see the video after the break). To make this happen, he found an LED flashlight that has rubber o-rings for waterproofing. Although small, there is enough space in the case to house the battery, driver, and laser diode. A thick ring of aluminum is placed around the laser diode to act as heat sink.
We’ll admit, we don’t know that much about lasers. This is probably the wrong question to ask, but now that he has this what do you do with it? Leave us a comment about your plans for this diabolical creation.
