[Oliver] received the Telly Terminator as a gift and decided to take a closer look at it. This key fob has two buttons; one shines an LED like a flashlight and the other turns off televisions. Sound familiar? Yeah, it made [Oliver] think of the TV-B-Gone as well.
He cracked open the case to find just a few components. The brain behind the IR signals is a Helios H5A02HP. Only a few pins are used for outputs so he connected a logic analyzer and recorded the signals. His writeup covers the process quite well. He takes a known IR transmitter protocol and compares it to the capture from the logic analyzer. It turns out that the fob generates 46 different signals and with further analysis concludes that there’s a chance the code used here is from an older version of the TV-B-Gone source.
