Whether it’s a new rocket, your latest quadcopter, or [Charlie Brown]’s kite, it always seems like there’s a tree waiting to catch and eat airborne projects. Sometimes you get lucky and find a way to climb up the tree to retrieve your wayward build, but most times you’re reduced to looking for rocks or sticks to fling up there in an attempt to shake it loose. But if you want to improve your chances of getting your stuff back, [U.S. Water Rockets] has a build for a retrieval tool made mostly from scrap bin parts that will help.
All you need is some PVC tubing, an old fishing reel and line, some latex surgical tubing, and a few dowels for projectiles. You can tell everything about the build from the BOM and stills, but the video after the break gives detailed instructions and shows it in action. Adding some fins to the dart or even substituting a cheap arrow from the sporting goods department of your favorite retailer might help with your aim. Even without fletching, the accuracy of the launcher is pretty good, and the range isn’t half bad either. Once the fishing line is over the branch that ate your quad it can be used to haul up successively stouter ropes, and pretty soon you’ll be shaking the tree like a boss.
Even if getting stuff out of trees isn’t on your immediate to-do list, this little hack could be put to other uses. Hams will use it to loft antennas up into trees, and tag-line placement for tree removal could be simplified with this tool. But if you still find yourself needing to retrieve stuff, you might want to be proactive and make your aerial robot tree-proof. That still won’t eliminate the need for drone-on-drone rooftop rescues.
Continue reading “How To Rescue Your Quadcopter From A Tree”
