[Derek Diedricksen] builds nomadic houses from left over building materials. Some are large enough to haul behind a vehicle or, in the case of the one above, small enough to tote around like a wheelbarrow. We love them because not only do they reuse material that might commonly hit the landfill, but they look good. Check out the first couple of episodes from the Yellow House series after the break. Then take some inspiration from [Derek’s] success and see if you don’t already have enough in your junk pile to get started.
