Cracking WEP
posted May 15th 2005 9:41am by
filed under: Uncategorized
ivlist
Tom’s Networking is running a two part series on how to crack WEP. WEP was pretty much broken from the early days of wireless networking. For starters the key length is misleading; a 64-bit key only has 40 unique bits. Some manufactures implemented poor random number generation. The seeds for the numbers are also reused which would never happen in good cryptography. This article covers the techniques the the feds used when they cracked a WEP key in three minutes. This works by grabbing a properly encrypted packet and then constantly sending it back to the access point generating more traffic. The more traffic you can capture the faster you can crack the network. Check out the article. I’ll be trying this out in the future when I get a Prism2 card and that DirecTV antenna wired up.
61 Responses to Cracking WEP
  • Ginotech says:
    i wish my card was supported by airsnort/aircrack… i have a hawking hwc54d hi-gain
  • Yeah, I’ve got two prism2 usb adapters, but hostap doesn’t support usb. Anybody got any pccard recommendations? External antenna connectors being a must.
  • micah buckley-farlee says:
    eliot, the one they use in the article looks good: http://www.wlanparts.com/product/NL2511CDPLUSEXT2
  • bucky says:
    I’ve got aircrack set up and running on Windows, but I’m having a lot of trouble generating wireless packets with only one computer (or even with two computers) for airodump to capture.
    I’m trying to get Cygwin set up right now to run the Linux scripts that are listed in the documentation, but without luck so far.
    Does anybody have any suggestions?
  • Brandon says:
    Is it possible to use a ppc to generate packets? I have an dell Axim x50v which has wifi i wonder if that will have the ability to generate some traffic on the network somehow.
  • zarlwilliam says:
    i use a Lucent Tech Orinoco card which isnt prism 2 based but it works. I use a Knoppix STD linux live CD… run kismet which auto patches the cards drivers to work then run airsnort. it’s easy.. oh.. and i mentioned the orinoco card cuz it has an external antenna connector. I got a orinoco silver AND a netgear wireless b router(which i took apart to remove a pcmcia wifi card which is prism 2 based) off ebay for $25 shipped. you really cant beat that. once again i suggest knoppix std for all you windows users that don’t want to switch over.
  • a says:
    I thought I would share the information that I put on my site. It is at http://www.peculiarlabs.com click on projects, then click on Cracking Wep. Its the standard WEP cracking information.
  • a says:
  • hayho says:
    When can we expect a second part???
  • Brandon says:
    soon i hope
  • hayho says:
    GREAT!!! thanks brandon – i probably wouldnt have checked for several days!! cant wait to get through this stuff!! :D
  • hayho says:
    DOH! It looks like my card isnt Prism II!!!
    :’( never mind – and excuse 2 go shopping :)
  • Prentice says:
    I successfully did this to my own network using an ACX100 card. It was kinda a pain to setup though (and operate on modules). Aircrack and Airsnort worked fine with it.
  • Request says:
    Nice post , can i have a code of the exploit or a name ?
  • yem says:
    I had this going quite well on two laptops using the Linux distro from the article. That is, until I got to the void11 part. It just wouldn’t run on either of my laptops. I kept getting device errors. Maybe it’s because I’m not using a prism2 card? PITA… ;o)
    Oh, and part 3 is up.
    http://www.tomsnetworking.com/Sections-article124.php
  • Edward says:
    I have a DELL Inspiron 2650 , im trying to load knoppix i couldn’t figure out how to get it to load up correctly – untill i had to load up the system with “knoppix noscsi” and after that, it loaded fine.. and didn’t get stuck anymore… so im in the system and i don’t know how to setup the orinoco wifi do i need drivers? is there a program i load up? is there a step by step process out there, i can’t find the how-tos in knoppix the wifi card has no power. Please email me at my g-mail account and also if u can tell me how to get the 56k modem to work because its not detecting my 56k on the laptop…. EMAIL ME dialntone@gmail.com
  • Gwenn says:
    Id’e like to say I’m actually on the receiving end of this hack and actually twice by the same person. Now I’m not wireless at all but at one point my DSL Modem had its wireless on in conjunction with the wireless capabilities my PC has it configured it self to the modem. Anyway now the hacker has taken over my Bios as well as the computer an HP AMD 64 2.4 gh not to mention my husbands computer a QP AMD athlon 900 and blew up my 6&8 yr olds amd duran 950. So my question to you guys is how do I get rid of this person or is someone willing to help?
  • Zukdizzle says:
    i picked up a network called Tony134 in my house and i wanna get into it, but i only have one laptop can someone guide me thru what i need to do to get the wep?
  • careyer says:
    Can anyone tell me how to crack WEP using only one notebook and one wireless card? In the article by
    Tom’s Networking it was mentioned that this is possible.
  • req says:
    are there any programs that support intel centrion chipsets?
  • Gar hiran says:
    i want to crack an hotmail email address. could you please guide me. it will help me not pay alimony to my cheating wife?
  • Death says:
    hey i need the software to hack a WEP code can you email it (and how to use it) to me at it999999999999@yahoo.com i have this old laptop but its junk so i want to use it just to hack stuff and i need to be able to crack a WEP code thanks for your help
    ————–Death
  • Jisn says:
    I can’t find my WEP code. I need it for a gaming device. How would I go about finding my own WEP code? I have a Linksys model WCG200-CC. vashstampede152@hotmail.com if anyone knows how. Thanks. Tried Airsnort, Couldn’t get my own using it. I might have used it wrong…
  • Pinkerton says:
    I want to know how to get past using the wep code to get the internet on my psp.
  • i would like to know where could I get the software as well
  • dude1 says:
    im new but can you’s tell me where to get the software to hack a wep code from please
  • none says:
    Gwen,
    I would try 1 method
    Set up a fake router.
    Secure it, Crank up the signal and see how many times he trys to get in keep a look in the log for his Mac address – at least you will be close to getting somthing on him, his mac is uniq unless he changes it. Than on a laptop run Kismet – or netstumber use the signal to noise ratio to pinpont his house – one the signil is bigger the the noise you should be look at his fron porch.
    Now for the fun part, ring the doorbell and punch him in the nose@!
  • none says:
    Gwen,
  • ed says:
    reply to: n2thepowerofn@yahoo.co.uk
    i just got a hp hx2790 pda and after running through all the wireless tools i could find, i has success with wififofum. none of the other usual packages would work with the built in card.
    now im on the lookout for a packet sniffer for it. anyone know a good simple program to run on wm5?
  • Dan says:
    I picked up 2 different peoples wireless and I want to get one of them… :\ i have a wireless card but I have dial-up, which is the reason I want to use their internet. So if someone can email me a program to do it with?
    squirreltakos@gmail.com
  • notanidiot says:
    Amazing to watch the comments here devolve into pure shite about “crackin my neighbors wifi”, “hack stuff” and (LOL) “cracking” a hotmail account. LMMFAO!
    And no, no Centrino chipsets are supported.
    Buy a cheap Netgear WG511.
  • kelaby says:
    Can some1 plz help me out i have acer aspire 3000 laptop running windows xp with a wireless bilkin adapter and im trying to hack into my school’s wireless internet but its encrypted with WEP does anybody now how to crack the code if anybody with the knowledge to do this plz contact me at kelaby89@hotmail.com
  • dante says:
    ok I need to find the wep code for a certain 2wire913 ok, It is my friends computer. He will let me use the wireless connection but only if I can get the WEP code I have to get it soon or its off. Can you help me? please anyone even visitors to the site please help me. email me at pyro1217@hotmail.com
    thanx -Dante
  • julia says:
    hi im wondering for all u hacker smarty pants if u can crack my beer.com password
    u got skill i wanna see it… it should be fun anyways
    hehehe
    email me at hoolie34@hotmail.com if u think u can do it
  • archana says:
    hi i am student working on project on how to crack wep in windows, so can u tell me step-by-step procedure of how to break it and the tools require to break it.thank you
  • Samuel says:
    Property in Malaysia.Condominiums, flats,villas, houses, and service apartments.
  • James says:
    please- tell me how to crack my neighbors WPA-PSC(TKIP)
    XP – desktop comp
    Please help me get psp internet
    cooljag@live.co.uk
    ps: if you read this, email me if you want to know how to as i will be glad to help if i can (IF)
  • abitaz says:
    There’s a step-by-step guide explaining how to do it at this blog http://n00bhacker.blogspot.com
  • now wep not safe for your privacy.just take a few minute for get the key..
  • RONNALD says:
    i use rt73 chipset.can support packet injection.but cannot inject at 500pps.i can inject only around 399pps.can someone tell why and help me?i cracking wep use windows.take around 10-20minute to get the key.so tired to waiting.
    i cracking use windows+vmware+usb wifi.i find tutorial here tutorial cracking wireless wep use windows
  • jassson says:
    ronnald,
    anyway where or which website u get the image aircrack that associated wth wnware at the blog (tutorial cracking wireless wep use windows)
  • Shaun says:
    Hey i have a psp and its got wlan i keep trying to hack people around my area to use there internet but they all have wep could you send me an email about how to hack them plz thanx shaun_boi111@hotmail.com
  • goat says:
    i have free internet anywhere, dumb fucks with no security wicked!!
  • Robert says:
    Hey I have a Broadcom 802.11 On Vista Service Pack One. And iam wanting to work on this to prove to my grandma that anyone can crack a key. So if anyone can send me instructions/ Software To do this it would be of Great Thanks.
    EMAIL robert_crawford@ymail.com
    Sincerly , Robert
  • crispy says:
    ok so is there any one uber noob way about hacking a wifi network? using a pda on windows mobile 6.1?
    i’ll buy 1st one a drink if it works!
    crispy
  • vinod says:
    I am using wireless netgear usb adapter 802.11g, 54mbps, 2.4ghz i am getting 2 unsecured, 2 WEP secured , 1 WPA-PSK, i gone with the setup i downloaded to hack WEP Key, the drivers are not working to my usb adapter any other solutions guys… unsecured networks are 0% – 5% connecting where secured connections are 50% i want to hack it now ..plz any one have to hack
  • The best software to use which is compatible with most cards can be found at http://unlockwifi.tk It has worked for me and all of my friends with a broadcomm chipset and netgear usb wireless adapters. Try it !
  • wow says:
    you guys are funny… just f****ng google wep cracker… theres tons of emm…. and if you cant crack a simple wep… you dont deserve internet
  • sdfgsdfg says:
    PLEASE SOME HELP ONE TO ME HAX TEH INTERWEBZ?!!@?
  • secret says:
    Please, can someone help me know how to hack the wifi on the space station? okay thankyou
    some@idiot.whatever
  • i really true. i really like your blog !!! thanks for the story
  • ashu says:
    is it possible to ping the wireless network and change the wep through command prompt like the net user command
  • Wep key hack says:
    There are some other ways to do it, just not sure which is faster and easier, thanks.
  • Hi there peeps, I just wanted to holla and tell you that I found a great site. For those of you who don’t want to spend stupid amounts of money on pay-per-view fees to watch UFC 108 online FREE in full HD. Far Better then spending $55.95 on it eh?
  • shawlar says:
    i have wireless network around my area protected with WEP can u send me DIY pls shawlar_001@yahoo.coim
  • Mark Apple says:
  • c17 says:
    there r several internet connections around me, but they are WEP secured. i want to get on with the dsi and wii, but of course it needs a password :( if anyone could email me a solution of some sort to possibly get past the password, help would be extremely appreciated! thanks! ( no downloads please!)
  • mikael says:
    I have a laptop HP 530. Does it works with this laptop?
  • Leave a Reply
    XHTML: You can use these tags: <a href="" title="" rel=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <pre> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
    Hack a Day serves up fresh hacks each day, every day from around the web as well as hacking related news.
    Send us your hacks
    Hacks
    Resources
