Reusing PCB components
If you’re anything like us, you have a closet full of old electronics, some broken, some obsolete. You can stop using those as paperweights with the help of this guide that shows you how to recycle and reuse PCB components.
The first step of the process is finding electronics you don’t mind taking apart. Next place the PCB you’ll be stripping in a vice, with the components facing away from you and the solder side facing towards you. Grip the component you want with a pair of pliers, and apply a hot soldering iron to the solder that is holding the component. The solder will melt and allow you to safely and cleanly remove the component.
This process can be applied to virtually any component on an PCB, and the author of the guide, [Patented], got a lot of components this way, including resistors, capacitors, switches, audio jacks, and much more. Don’t forget to toss any free-floating metal or plastic parts in the recycle bin when you’re done. You can feel good about the fact that nothing was wasted, you found parts for your next project, and you cleared out some space.
Comments
  1. Mordanthanus says:
    I’ve been doing this since I was 8 years old… there are ALWAYS good parts on old boards. I hope someone doesn’t think this is a new idea, I was 8 over two decades ago…
  2. MEAT! says:
    That’s the ‘technique?’ To hold the thing and heat the hell out of it until the entire component is hot enough to pull free? How are you going to heat both sides of the component at once? Let the internal structure transfer the heat?
  3. I love salvaging parts. I find it relaxing. Not much useful information in that instructable. A lot of the time you can gets parts off by just cutting the board with wire cutters right up to the leads of the components. That way you don’t risk cooking the parts.
  4. john.s948@mint.us.to says:
    *yawn* i can desolder stuff. wow.
    useful hack but get yourself a desoldering iron…i got one for
  5. LinuxH4x0r says:
    What a waste. He is taking apart WORKING electronics for parts he probably won’t use. He didn’t know the difference between a ceramic cap and a resistor. Do you really think he will use them properly, if he even uses them at all?
  6. fermicirrus says:
    Better than a de/soldering iron is a heat gun from harbor freight. $10. It cvers a larger area and works really well. Ive salvaged 1000s of parts with great success. It will burn the board but you probably dont need it anyway.
  7. quasi says:
    yawn…. how about some actual “hacks”
  8. metiz says:
    Or you could use a haot air gun for components that have more then 2 connections on the board. Makes life a whole lot easier
  9. Schnulli says:
    O_o I’ve also been doing doing this for years. You don’t want to know how many boxes of old PCBs i have lying around… I also tried the version with a heat gun once, but it only burned the board instead of making the components fall off. By the way: I never buy resistors or caps ^^
  10. chr0n1c says:
    just last night i pulled 6 relays, lots of diodes, about 75 resistors, a sweet transformer, a bunch of big caps and some rca jacks/speaker connections out of an old JVC tuner that someone was going to throw away! i have already built a 15vdc power supply with the transformer, a few diodes, two caps and a lm7815. everything but the small cap came out of the tuner. plus i have a sweet shell to build my DIY synth into with recyclable buttons already mounted on the front.
  11. dip says:
    Not useless, but the leads on these things are so short! How am I going to fit it in some breadboard?!
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
