Pelican case Xbox 360
We were surprised the last time [Ben Heck] was building a Xbox 360 laptop, yet here’s another one. Well, it’s not a laptop exactly, but an Xbox 360 built inside of a Pelican case. After receiving several requests for a similar device for people stationed overseas, he finally decided to try it out. The goal is to get all the components into the case so that the watertight seals are intact. It’s only partially complete right now and he notes that one of the major hurdles will be converting the DVD drive to top loading. The light ring and USB ports will probably be moved to the top surface, and the hard drive will be made removable. We look forward to the final writeup since there aren’t many tutorials on working with Pelican cases.
Comments
  1. mike says:
    The only other thing it needs is some sealed lead acid batteries and a solar panel with a charge controller so that the dudes over seas can play it in a tent or the back of a truck or anywhere else they might be.
  2. strider_mt2k says:
    Pelican cases are extremely easy to work with as long as you aren’t trying to keep the seals intact!
    They rock in general.
    Check out the warranty on ‘em.
    I think they are covered against everything except shark attacks and children under six!
  3. backwards says:
    he is trying to hard to make the DVD top loading.
    He should just make the whole dvd player similar to top loading.
    That is, he should spring load the dvd case, so that , one must depress the dvd case, which then pops up allowing the front of the player to be exposed.
  4. nubie says:
    Exactly my thoughts backwards. But why not have it angled permanently? No moving parts.
    @ Strider, he is keeping the seals. He must be using an adhesive to attach the components.
  5. Mick says:
    hes using industrial strength Velcro to secure things
  6. barry99705 says:
    You can bolt through a pelican case and keep it water tight. Just needs rubber washers on the heads. I built a computer out of a pelican knock off that has rp-tnc wifi connectors on the outside that’s still water resistant. I wouldn’t try to float it, but rain wouldn’t hurt it.
  7. just a heads up, we buy our pelican cases from cases-4-less.com. I’m not affiliated with them in any way, they just have extremely good prices on Pelican Cases – about half the price they are at fry’s if you buy them without the foam (we use custom foam for our products), or still much cheaper if you do get foam. Their website looks kinda sketchy but i can vouch that they are a decent company.
    -Taylor
  8. Bah, i fail, there are no dashes in the web address, it’s cases4less.com
  9. xSmurf says:
    I think he wants a perfect seal for the Seals ;)
  10. brian says:
    use a usb converter its made for the ps,gc and the 1st xbox to work on a windows base pc but can be used on 360 as it has two usb ports you can move the box to the side so you can locate the usb ports plus it gives you an extra usb port also get two usb converters and have two extra usb ports
    http://www.wweppvshow.com
    email me at bricam63863@yahoo.com as i have lots of ideals
  11. Free Gadget says:
    Nice blog adding this to my twitter now
  12. Free Gadget says:
    Thanks for the info… RSS feed added
  13. Free Gadget says:
    Great reading, thank you
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
