Xbox 360 jasper in the wild
jasper_5
[Ben Heck] has written up what he calls a “super unboxing” of the new jasper Xbox 360.  The “jasper” refers to a new graphics processor that is supposed to be smaller and more reliable. They have been hard to find, but [Ben] shows us how to spot them. Simply look at the sticker on the back of the unit that shows voltage/current. If it uses 12.1 Amps instead of 14.2, it has the jasper.
Comments
  1. Hexxeh says:
    Voltages? Don’t you mean current?
  2. James says:
    So that wouldnt be “look at the voltages” then, it’d be “look at the currents” ;-) Pretty elemental flaw for a technology site lol
  3. CalcProgrammer1 says:
    Lol, I have an original (Xenon) 360 but a Falcon 175W PSU for it. Due to the annoying forward compatible plugs I had to take a file and cut out the divider that prevented the plug from powering the old console, but it works fine (been using it for over half a year) even through long gaming sessions. The PSU puts off some heat but the fan keeps it fairly cool. I got it because my friend replaced his dead original 360 (which is now mine) with a Falcon Arcade model but kept his original power brick, having only the new brick and an RRoD console I didn’t want to invest money in a new brick, so hacking the newer one worked fine.
  4. Turd says:
    Wow you guys really can’t read can you?
    I quote “look at the sticker on the back of the unit that shows voltage/current”
    This mean look at the sticker where it shows you the volts and amps. Not “look how many volts it takes- 12.1 amps or 14.2″
    l2read
  5. CalcProgrammer1 says:
    You do realize they can edit articles? After the above posters pointed out the flaw, the author corrected the page :)
  6. RyanT says:
    Is it just me or is 14 amps a little high for a graphics processor? My kiln only uses 15 amps…
  7. calebkraft says:
    yup, that sentence was worded goofy. I fixed it. good eye guys.
  8. Bob says:
    @ryant
    the 14 amps is for the whole xbox. not just the graphics processor.
  9. josh says:
    That’s also 14 amps at the rated voltage. ~175 watts, as one of the prior posters mentioned.
    Your kiln most likely is running at 120 or 240 volts, so 15*120=1650 watts, or 15*240=3600 watts.
    Just a wee bit more than an xbox 360 draws, though I saw the power brick called a foot warmer in some of the early reviews!
  10. vespine says:
    14 amps?? No way! Not even for the whole box, maybe for 10 of them. Domestic power boards are generally rated to 10 Amps, which is the size of a decently powerful space heater! I just had a look at my PS3 and it has 1.7 Amps on it.
  11. Bertrix says:
    The 14A is at a voltage of 12V, so only about 170W…
  12. vespine says:
    ok, i hadn’t hit reload on this page after surfing round for like over an hour, so it now just looks like i’m thick… which I am in no way trying to deny, but the post above mine does actually make sense…
  13. lawlz says:
    A Jasper in the wild! Quick bubba, get the rope!
  14. vdubgolf_03 says:
    i have a new jasper. i hope it is better then the other ones. but one ?, are you able to hack the jasper model xbox 360, or is it the older ones that can only be hacked?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
