RGB VU Meter
[Simon Inns] turned out this VU meter with a 16 RGB LEDs. He’s using three 16-bit TLC5940NTG LED drivers for the project. They’re not cheap chips but they do a great job. If you were looking to save on parts [Simon] found there’s more than enough brightness and any loss due to multiplexing would not be a problem. The device connects to a computer via USB thanks to the PIC 18F2550 which he’s used in his past VU meter projects. One of the design choices he made was to use a switching power supply. The LM2576 (datasheet) has no problem sourcing 3A at 5V and in addition to two electrolytic capacitors which are commonly used with linear regulators, you just need to add a diode and an inductor.
The meter offers several different configurations which are set on the PC side of things. These include the colors that are used and if the entire bars is used as one meter or split into sections to display both audio channels. Check it out after the break.
[youtube=http://www.youtube.com/watch?v=J3BraNUj2cY]
18 thoughts on “RGB VU Meter
  1. @Tim
    Sounds a cool idea but will end up as a psychedelic light effect instead an actual VU meter. People will not be easily able to differentiate low/mid/high frequencies from a composite (RGB) light.
    I would however put three rows of filters corresponding to R,G and B respectively side-to-side on top of the leds, to split the low/med/high frequency levels.
  2. Those LED drivers can be awfully expensive. (Well, unless you ask TI for samples, then they are free ;))
    Instead, you can use your microcontroller to multiplex the LEDs instead. Overdrive them just a bit (but under the LED’s max pulse current rating) to maintain brightness. Be careful though, because this method can make it easy to burn out the LEDs if there is something wrong with your multiplexing code and you keep the LED on for too long!
    -Andrew
  3. Perhaps instead of 3 overlapping bars, make it into a sort of spectrum analyzer with each led representing one frequency band, and its color relating to its intensity.
  4. The amount of hifis, mixers etc gets thrown into the trash with far better vu meters/year is fuckhigh. So why dont u just go to the junkyard get some. He calls this expensive hah. I wouldnt pay a 1$ for this trash.
  5. @MrX: I guess it depends on what you are using the meter for… Some people are audio engineers.. To me they are pretty much a decoration. It should be easy to expand the interface to include /all/ of these ideas.
    @AnarKIT: yeeeeeeah
  6. Mike, found your circuit while searching the web.
    Decided to clean-up the PCB layout using the four sided board layout, also using a different 5 volt Reg which is now heatsink to the top and bottom side of PCB with feedthrough. The shorten the PCB somewhat. After that made another board using SMT parts instead of feed through holes and DIP’s. If you wish a copy of PCB layout could send it forward.
Leave a Reply to AndrewCancel reply
