Digital measuring tape
You’ll never come up short with this measuring tape. That’s because there isn’t actually any tape in the device; it measures distance based on the rotation of a wheel. Roll it across the room and you’ll get an accurate measurement of the distance the little bugger traveled. Like the Etch-a-Sketch from Monday this uses the encoder wheel from a mouse as the input. The IR emitter and sensor from the ubiquitous peripheral find a new home on the PCB that hosts the PIC 16F819. It monitors the rotation, turns it into inches, then spits that number out on a 7 segment display. Handy, and cheap!
Comments
  1. Bill D. Williams says:
    I think the real hack is how he used his pet gerbil to make the window in the case.
    You know, hacks don’t have to look like ugly … just sayin’.
  2. MS3FGX says:
    Certainly won’t win any beauty pageants, but very clever.
  3. bluewraith says:
    I agree with Bill.. a $15 file set will do wonders.
  4. cool hack but he should really invest in a nibbler tool. $10 at the Rat Shack…. it’s a must have tool for any “case mods”.
  5. oxid says:
    best part about the traditional measuring tape is that you don’t have to touch the surface your measuring.
  6. Mike says:
    Or if there is no surface between the things you are measuring…
  7. Aero says:
    What’s a Calib Rate?
    :-P
  8. Brennan says:
    @oxid
    …your measuring what?
  9. anonymous says:
    Cool idea, but I think accuracy would be a problem unless you rolled it in a *very* straight line.
  10. Charlie says:
    So, it’s a pocket sized surveyor’s wheel?
  11. Drone says:
    Nice, I wish it had a power sipping LCD and ran on button cells.
  12. Brem69 says:
    If this is made to do a job they find other device’s don’t do so well Then worth the build as in the end they may save time and money
    Good Job
  13. svofski says:
    I’m not sure, but aren’t such devices called odometers?
  14. svofski says:
    Actually, even, Opisometers!
    http://en.wikipedia.org/wiki/Opisometer
  15. strider_mt2k says:
    Hatin’ on the enclosure makes hacky jebus cry.
  16. draeath says:
    @Brennan
    Open space?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
