Noise generator ported to run on small AVR, also Arduino compatible
Feeling a bit left out because he didn’t have a PICAXE on hand, [Rob Miles] decided to port the Luna Mod code so that it would work on an AVR chip. He chose to build his around an ATtiny45, but also mentions that this is Arduino compatible.
This case layout is a bit different from the original Make version, … Read the rest
Old pachinko game tweaked to add a reward system
restored_gumball_vending_pachinko_machine
[Tim Higgins] picked up an old pachinko game at a garage sale for his wife, but it ended up sitting unused in the garage for a few years. When he finally dusted it off, he decided that he wanted to restore and build a nice cabinet for it, though he thought the idea was a bit lame.
He says he … Read the rest
Announcing Hack a Day Themes
High Voltage Theme graphic
Starting next Monday we be adding some themed posts into the mix. Every couple of weeks we will pick a new theme. Our first theme will be about hacks and projects involving high voltage.   Each day we will have a new post based on the current theme. To make this happen though, we need your help.  If you have been … Read the rest
Home automation systems easily hacked via the power grid
x10_home_automation_hacked
As home automation becomes more and more popular, hackers and security experts alike are turning their attention to these systems, to see just how (in)secure they are.
This week at DefCon, a pair of researchers demonstrated just how vulnerable home automation systems can be. Carrying out their research independently, [Kennedy] and [Rob Simon] came to the same conclusion – that … Read the rest
