Turning toy pianos into MIDI keyboards
Building a MIDI device is always a great microcontroller project, and nearly everyone has an old toy keyboard lying around in the back of a closet or in the basement. [JenShen] decided to take one of these toy keyboards and build a MIDI keyboard.
The keyboard [JenShen] used was a simple Casio keyboard with built-in voices. After tearing out the guts of the keyboard, the only thing that remained is the row of push buttons underneath the keys. These buttons were laid out in a row/column matrix, so [JenShen] needed to decode this matrix before sending the result to an Arduino for processing.
A 74HN595 shift register was used to read the 8 rows of buttons underneath the keys, while the rows were tied to different input pins on the ‘duino. This allowed [JenShen] to scan the keyboard matrix with an Arduino and generate MIDI notes and send them to other synths.
In the video after the break, you can check out [JenShen]‘s circuit and code that allowed him to turn a toy keyboard into a proper 32-note MIDI keyboard. It’s not velocity sensitive, but he says he’ll show everyone how to accomplish that in a future post.
Comments
  1. Bill Gander says:
    Love it :)
  2. AndroidCat says:
    Nice, but I was expecting one of the old classic mechanical toy pianos.
  3. John says:
    What’s the clock rate for the shift register and what’s the total response time (from keypress to MIDI signal) for the whole setup?
    • JenShen says:
      Hi John, I’ve left it default 16Mhz clock. so each of 8 columns scanned with about 2Mhz clock. I have not played much with this but I believe clock speed can be reduced to save some power. Response was not measured but it is by feel is instantaneous.
  4. James says:
    Great job would have liked to see the original functionality maintained with this setup also. with a midi in so that you could send midi in to the keyboard and get the Casio sounds. :) that’s a mod we did a long time ago http://www.illuminatedsounds.com/?p=10
  5. Barry Carter says:
    There is always this classic
    http://www.headfuzz.co.uk/midihack
  6. JenShen says:
    Hi All, I’ve prepared a follow up post on how to add Velocity sensitivity and Aftertouch effects to the project. Read more here: http://www.codetinkerhack.com/2013/01/how-to-add-velocity-aftertouch-midi.html
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 93,568 other followers
