A Small Replacement For Large Programming Headers
Tag Connect Programming Headers
No matter how small you make your embedded projects, you still need a way to program the MCU. Standard programming headers can be annoyingly large for those very small projects. [Danny] wrote in to tell us how we can save room on our PCB designs using special spring loaded connectors, rather than large headers.
There are so many small embedded development systems, such as the Trinket that still rely on standard headers. Reducing the size of the programming headers and interface headers is an issue that deserves more attention than it currently receives. Based on Tag-Connect, a proprietary connector built around pogo-style pins, your PCB does not actually require any on-board mating connector. The PCB footprint simply has test-pads that connect with the pogo-pins and holes that allow for a rock solid connection. While the Tag-Connect header is a bit expensive (it costs about $34), you only need to buy it once.
It would be great to see even smaller Tag-Connect cables. Do you have a similar solution? What about something even smaller and more compact? Write in to tell us about any ultra-compact connector solutions you have been using!
73 thoughts on “A Small Replacement For Large Programming Headers
    1. There are a couple reason. An edge connector can require a non-square PCB and possibly non-basic PCB fab methods. An edge connector is most likely larger as well. The non-locking 6-pin connector is about the size of an 0805 part. You can put it right next to where it needs to be instead of running traces to an edge. However if you need more signals or power, an edge connector is probably the way to go.
      1. Just shrink the pad size down and don’t use the version that has those huge goofy mounting holes, they have one that clips onto the metal pins, so what’s the point in using a 7-hole footprint if 3 works the same? (given that you have access to the backside of the board)
  1. i have used these for years now and they work well for a product … if you plan on reprogramming it over months than either solder a proper header on to them as the pads will wear out!
    the full size locking one is not much smaller than a simple header and if your going that route just go for the low pitch headers … but the small non-locking “production” one works great! never missed a programming due to the connector and never had a “plug” break on me!
  2. I’ve used the Tag-Connect on the last few designs I’ve done and I think they are amazing. I’ve have both the locking and non-locking cable with an ST-LINKV2 in SWD mode. One thing that isn’t mentioned on any Tag-Connect documentation I’ve seen, is that the tips of the pogo-pins they use have several small spikes on the end. I’ve been able to re-program boards after conformal coating, because these spike poke right through.
    1. Agreed on the 3D print aspect. As the post far below says, make a jig and print around it.
      If the print head is too large to ‘fill in’ the area, one option would be to print a ‘shell’ and fill with epoxy/HMA (hot glue). Most commercial cables that I’ve deconstructed are using an HMA injected into some sort of casing anyway.
  3. The tag connect is nice and all, but an AVR still requires 6-pins for a AVRISP interface. Or a crowded 2-layer board, connecting all the signals to an AVRISP interface can be a challenge. On a lower pin-count AVR the AVRISP eats up a lot of useful pins.
    I was excited when Atmel announced the debugWIRE inteface. It only requires two wires (ground and the reset pin).
    Unfortunately, the debugWIRE is not enable by default. You need to change the fuse setting to enable debugWIRE (which requires the AVRISP interface). In my opinion, this cripples much of the advantage of the debugWIRE interface.
    AFAIK, there is no source for AVR parts where debugWIRE has been enabled at the factory.
    1. The other problem with debugWIRE for battery-powered devices is that the chip will use more power while it’s enabled.
      So you’ll want to disable it for many production devices anyway.
      1. No, I have a software reset that is triggered when a special character is sent. For instance, on NXP LPC, a ‘?’ character forces a jump to the ROM bootloader. In case that doesn’t work, there’s a manual reset switch (or just a bare contact somewhere on the board that I can short with some tweezers).
        I have no interest in a ‘real’ debugger. I prefer some printf()s, and maybe a few blinking leds for real time stuff. Speed is usually not a problem. And in the few cases that I’ve written big programs, there’s always been something like an ethernet interface to load programs with.
        1. A huge advantage of printf()-style debugging is that you can also debug remotely. Sometimes I send a customer a debug image, they capture the output log, and e-mail that back to me. This can be very helpful when the customer is on the other side of the world, facing a one-in-a-million problem. It only requires a 3 pin cable with a TTL USB UART on the other side.
  4. You could cheaply and easily reproduce this with two pieces of PCB spaced slightly with the pogo and alignment pins soldered onto the back pcb protruding through the front PCB, then just route the pins to a standard connector…
  5. I’ve had good results with a 0.05″ inline header!
    Here’s an ISP to ‘micro’ ISP adapter I built, breaking out reset and power injection capabilities. It’s so thin that it easily fits into most board footprints.
    http://i.imgur.com/SzSM0J1.jpg
    (Sorry, no pictures of the target board I can share)
    A 6-pin male header solders to the adapter.
    The target board has a matching row of 6 holes.
    The adapter is just pressed at an angle to the target board, and makes good contact.
    If you need to program a development board over and over, you can just solder a female header onto the target.
  6. We use tag-connects on our production boards – for programming and debug.
    I use the for my personal stuff too – I build panelised boards – the cost of buying 45 tag-connect cables to put into a test fixture is a real problem – the pins are on 0.5 mil centers finding tiny pogo pins to make replacement fixtures is hard and is my current project
  7. Are you guys spying on me? My current project uses a K-thermocouple with a interpolated lookup (which you covered on Saturday) and I should have a TagConnect cable on its way to me so I can ditch the pin header I normally use. I may do a couple of boards with both headers to start with.
  8. I built something like this years ago, i just used the standard AVR ISP layout, but replaced the through hole mounting with same size bare copper pads, then i put pogo pins on a board and attached it to a clothes pin.
    Since i don’t have any holes this is great for boards that need a clean look on one side.
    The bonus is that this solution will also work on unmounted standard ISP headers.
    https://www.youtube.com/watch?v=SPft3X8aTJA
  9. In a current project I have SPI routed to a flexprint header. If you’re at liberty to add another signal to the header, add reset and you’re good to go. Otherwise a pad next to the reset pull-up and a single pogo pin will do.
    tag connect has caught my eye before but I cannot see how the locking version will survive many mating cycles.
  10. These are great. I’ve been using them for several years now and have never had any issues!
    One thing worth mentioning is that, if your board has two microcontrollers, you can reuse the same alignment pins if you place the second set of programming pads in the same location but on the back side of your board. The only caveat is that this approach doesn’t work well if you only have access to one side of the board (ex: if your board is secured in an enclosure).
  11. Instead of board-edge connectors or pin headers, I came up with my own method for some small battery management boards I made. I put 4 pads along the edge of the board, then used hot glue to mount 4 wires on a plastic paper clip (see the photos below). Those 4 wires are the MISO, MOSI, SCK, and Reset pins. The Vcc and GND go through the programming/calibration tool I made, but you could just as easily use 6 pads instead of 4 to have it all on the edge. To program it, I just clip the tool on to the board and upload my code from the IDE.
    Photos:
    https://dl.dropboxusercontent.com/u/301235/EV%20Project/programming1.jpg
    https://dl.dropboxusercontent.com/u/301235/EV%20Project/programming2.jpg
    https://dl.dropboxusercontent.com/u/301235/EV%20Project/programming3.jpg
  12. When I first saw the picture I thought it was a modified DB-9 connector. I wonder if a person could do it that way too by using a DB-9 female with rigid pins of some sort on 3 outer pins and pogos plugged into 6 of the inner ones.
  13. In one of my projects (digital watch with color Nokia LCD, ATmega8A, LiPo Battery with ultra-simple charging method), I used a MicroUSB port for charging and software USB (V-USB). Also I connected the three pins of the MicroUSB port (other than +5V and GND) to SCK, MISO and MOSI. I also made a special ISP to MicroUSB adapter (with the addition of a manually connected RESET pin on-board). In this way, in normal situation, the MicroUSB port acts as a normal port for USB connectivity and charging. But when you connect the special yet simple adapter, it acts as ISP. The only thing is that you still have to connect RESET with a wire to the ISP. But I omitted the ISP port completely without losing its function.
    I will write about my projects someday in my new blog (http://me.gheysari.com – don’t click! Nothing’s there yet!).
    Actually I’m looking for votes about which of my projects should I post first on my blog. Please help me decide which project is more attractable to post as my first blog post?
    1. The aforementioned watch.
    2. An Arduino compatible innovative unlimited extendable development board with various modules. The modules connect to the main board or each other with an edge connector. Each module has one edge connectors on each side which are connected together. So you can connect as much modules as you want together instead of stacking them like Arduino shields which is limited. There is also connectors like Arduino on the main board to connect shields or use for experiments. Dual voltage 3.3/5V. Simple software USB connectivity without FTDI. Arduino compatible USBasp bootloader only in 2KB.
    3. An infrared sensitive counter
    4. A remote controlled vibrating dildo with programmable vibration patterns
    5. A touch color LCD development board with ATmega128
    6. A recorder/player for 315/433MHz remote controllers which is able to open any car/garage door/etc,
    and other projects.
    1. The charger that I design/built uses the SPI to talk to the Nokia LCD. I added the extra reset line and use the same connector for both LCD and ISP. I had the ISP cable connected during my development as it doesn’t interfere with the board in normal operation. LCD only uses MOSI, so don’t have to worry about contention issues and programmer tristates its pins.
      1. That’s also a very good idea! Small and useful. Plus you have 10 pins which gives you 4 extra pins for other things such as UART debugging. The connector is also easy to find, cheap and has good quality.
  14. We just started using these where I work, they’re lovely for manufacturing. We standardized a pinout for jtag and microcontroller programming interfaces on the same connector so as far as manufacturing is concerned, you just push the pins onto the pads, push a button and the device is programmed.
    Might not be as cost effective for one offs and homebrew, but I imagine putting some pogopins on a 2mm pitch type connector would get a similar effect.
    1. I search for ” AVX 9188″ on digikey’s site and found it. AVX’s part# is 009188006020062
      digikey’s part#: 478-5491-1-ND
      That AVX connector looks good. At $1.21 QTY 1, it doesn’t break the bank either even if I stock 10 of them.
    2. This, my friends, THIS is the solution. It’s got everything tag-connect’s got without the single-vendor. You could conceivably implement this with surface mount pogo pins (something like Mill-Max 0910-1-57-20-75-14-11-0, Digikey ED90454CT-ND) and get rid of the AVX connector if that’s a problem.
      Great post, thank you very much for the tip!
  15. Picaxe programming usually requires a standard stereo headphone socket which makes things simple and easy, but when I’ve soldered boards with SMD Picaxe chips it seems a bit ludicrus to include a large socket that dwarfs the microcontroller in the case of the 8 pin ones.
    So I’ve started using my own 2mm pin header arrangement, GND in the center and TX & RX on the outside, it doesn’t matter if I plug the cable in the wrong way round as nothing will happen.
  16. Mill-max makes 0.1″ pitch spring loaded contacts in single or double row.
    These looks like a professional alternative of soldering or hot gluing pogo pins trying to make a programming plug for a PCB for the unpopulated header.
    You can search for it at digikey: “ED817” for double row, “ED819” for single row.
    They are in the less than $30 range, but have 64 or 72 contacts which looks like you can cut/file them down into smaller strips. Digikey also offers to cut them for you for a fee + # of pins.
    Reading their 2896 pages of catalog now. By the time I am done, there will be half a dozen newer rev already.
  17. I use a 1mm pitch header with through holes designed to fit snugly. ARM SWD needs only 4 pins. I solder it to either a ribbon cable or flex cable, and then on the other end to the debugger.
  18. Not a fan of the tag-connect myself. If you don’t get the one with the latch then you’re holding the thing down against the board. Not a problem for simple flashing but for debug it’s a no-go. They do have a “retaining clip” that mounts on the bottom of the board and attaches to the through-hole pins but this bends over time and loses its retention force.
    In a production environment you should already have a bed of nails to test the board with, and it’s trivial to grab another 6 or 8 pins for JTAG on the fixture.
    All in all it’s a nice idea but proprietary and pricey. Was this post an ad?
  19. I’ve been using 1.25mm headers like Molex 53047s: http://www.digikey.com/product-search/en?vendor=0&keywords=53047-05
    The unpopulated through-hole connector footprint is on the board wherever is convenient, squeezed down to minimum size (minimum drill size and small annular rings, etc.). I’ve just soldered rainbow wire to the “top” of a connector to form the programming cable (the other end has a programmer-specific connector), and epoxied it for longevity. To program, the exposed pin end is inserted (as if populating the header for real) and momentarily held in place by finger pressure. Of course, for any kind of longterm debugging one can actually populate the header properly and connect to it with the appropriate mating end.
    Of course, then I started playing with EFM32s and rendered this mostly moot: on these there is a preloaded serial/USB bootloader that is accessed by driving Vcc on one of its in-circuit programming lines at startup. For production this is way easier than fiddling with any tiny programming cables or one-off pogo jigs.
Leave a Reply to Eduard ScheskeCancel reply
