Run Linux On Gmail
Linux Code
yes you read right. it’s possible to install linux on gmail. richard jones wrote some python that allows you to mount linux within gmail. you can use all kinds of unix commands to communicate with gmail like ls, rm, grep, cp, etc. it’s an ongoing project in development but it’s very cool and allows you basically a 2gb virtual drive of sorts. you’ll need to have libgmail and FUSE at hand to make it work properly. libgmail communicates with gmail while FUSE provides the filesystem. Give it a shot, it looks like it’s progressing very nicely.
51 thoughts on “Run Linux On Gmail
  1. just another thought…
    you could get a floppy bootdisk, and then chroot to /gmailfs with a base fs installed, and then it could get quite interesting.
    I wonder how google would feel about that.
  2. Just a thought after some of your comments:
    What about Darwin on Gmail? X11? What are the possibilities? Terminal? Telnet? Etc? Could it be possible to even run an FTP? Dig around and let’s find out. I mean we all have like 90 invites anyway.
    -Vince V.
  3. I don’t really see the point… are you saying you could “boot” from Linux anywhere if you had those two programs? If that is what your saying, is that possible with windows?
  4. You can’t actually “mount linux on gmail”, but you can mount gmail accounts as drives in linux. Deceptive headline.
  5. I think you mean the other way around. You can’t ‘run linux on gmail’, how would you boot it?
    What you can do is mount your gmail account under linux, like you mention. This has been possible for some time, under Windows. Good to see it’s working under Linux now.
  6. polymira is right, the article simple describes using your gmail account as a storage system. This entry is worded incorrectly.
  7. yeah, isnt that run gmail on linux?
    You would never be able to boot from gmail without some sort of bizare hardware hack that made the pc think gmail was a drive. there would need to be an interpretation of the transfer protocols by the network card. Otherwise youll prolly be booting to linux to boot linux from the gmail
  8. It’s not running linux off gmail! duh! It’s just mounting a mock filesystem via gmail.
    For example, if you were running linux, you could mount your gmail and store files there.
    again… IT IS NOT RUNNING LINUX ON GMAIL
  9. this hack lets you mount a filesystem stored remotely in your gmail account.
    Idea: take a small linux distro, floppy or cd or usb based. Now, include these gmailfs libs, mount the drive as /mnt/gmail, then run a ‘chroot /mnt/gmail’. Voila, your / is now running off gmail. Use the documentation from http://www.linuxfromscratch.org/ and you’ve got linux, running remotely stored information on gmail. Linux, on gmail.
  10. I think this would be useful for placing a WRT54g in the wild. Running openWRT you could plug the router in somewhere with an internet connection or even use it wirelessly and as long as you could reach gmail the router would have 2Gb of file space. This could also be used to remotely update the software.
  11. I don’t folks. I think you could run Linux off of Gmail. Ponder this.
    Run Qemu, with a virtual drive that is connected to gmail. Boot from that. The host pc could manage the connection, and it would be transparent to the Guest OS
    OMFG Windows XP on Qemu on Gmail!!!!!! AHAHAHAHAHAAHA
  12. I heard that gfs was SUPER slow, I talked to a guy who has a small partition on his linux box, he says when he runs ls, it takes about a minute.
  13. even if it were worth it to mount linux on Gmail, i have a feeling Gmail would turn around and mount it back, just to show who’s boss
  14. I never had thought about that with the WRT54G… have 2 myself, running a 3rd party firmware… and i think that if gmailfs could be running on it, you could do something like run snort on it and have all the logs go to the gmail account…. could be fun.
  15. It’s been around for Linux for months, too. From the GmailFS site linked to by the article:
    “Saturday August 28th 2004
    Released version 0.1.”
  16. “even if it were worth it to mount linux on Gmail, i have a feeling Gmail would turn around and mount it back, just to show who’s boss”
    Well duh…
    Gmail’s storage keeps increasing doesn’t it?
    Where do you think it’s all coming from? ;)
  17. #25 – sorta creating a stiped raid system, effectivly allowing 20mb files to be stored, and 4gb of space!
    i love the idea of using it for wild routers too
  18. Guys who have been saying “Windows has had this for aaages”.
    Linux had this way WAY before the windows apps were being circulated. As is nearly always the way with cool hacks.
  19. has anyone here actually gotten this to work? i keep getting errors relating to the parsing of the inode number out of the subjects, which seems to be caused by libgmail no longer parsing correctly, therefore breaking gmailfs. apparently libgmail is putting the date in the subject variable
  20. never mind my last message. it took a bit of hacking in gmailfs.py and the cvs version of libgmail to make it work but i got there. still a bit buggy. perhaps there are problems with the version included in the debian package
  21. for those talking about gmailfs working under linux, it worked there long ago, then made it to windows, not the other way around. But I don’t think that’s what this article is even talking about
  22. No one said it came to windows first, i just said that (because this is old news… not breaking news) that as of right now, the windows solutiom has been around for a long time … within a 3 month time span of gmailfs .. which has been around for what … 10 months?
  23. Do you really think u’ll be able to have those 50 accounts open for a long time without Google closing at least a few of them?
  24. its just as adding another drive to ur machine, but is remotly located and could be accessed thru gmail. Is it anything else ?
  25. its just as adding another drive to ur machine, but is remotly located and could be accessed thru gmail. Is it anything else ?
  26. Interesting. But not totally fixed yet.
    As Kevin mentioned, its going to take some hacking on the latest libgmail cvs. and its not just the debian package..
  27. Ha ha ha. What we need down is a LUFS module for mounting GMail accounts, along with support for combining multiple accounts with RAID ! Then you can take your 50 invites and have a spare 100GB remote filesystem, w00t.
    But in reality I hate GMail and their evil privacy policy, and I wouldn’t touch it with a 10TB pole.
  28. Sounds pretty neat, but I wish Google (the company) would actually condone this. However, I guess the whole issue with using g-mail as a filesystem of any sort is that it circumvents all of the advertising. Then again, so does using gmail with pop3 and thunderbird, so maybe that’s not why they don’t like it.
    Does anyone know the official reason why Google doesn’t like this kind of use?
  29. #43 I’m pretty sure they don’t like it because to them it would just be a big waste of space, bandwith, and account names. It would also probably crash the servers if all the linux users just started making raid arrays of all their accounts, and puting alot of files on them.
  30. 45 & 46 means:
    hi… how are you/we all (45)
    great page (46)
    :) Vou ter k testar isto :) (48)
    i’ve to try this (48) :)
  31. http://WWW.YOURHACKERS.COM
    100% SUCCESS HACK YAHOO! HOTMAIL AOL GMAIL etc.
    IF YOU WANT TO HACK ANY ACCOUNT IN YAHOO HOTMAIL GMAIL AOL etc.
    VISIT US NOW http://WWW.YOURHACKERS.COM
    WE PROVIDE 100% PURE SATISFACTION TO OUR CUSTOMERS WE WILL PROVIDE YOU STRONG PROOFS BEFORE YOU PAY US
    WE PROVIDE CURRENT ORIGINAL 100% WORKING PASSWORDS
    JUST VISIT US NOW FOR MORE INFORMATION http://WWW.YOURHACKERS.COM
    YOU WILL BE PROVIDED WITH FOLLOWING PROOFS BEFORE PAYMENT,
    SCREENSHOT OF THE VICTIM’S MAILBOX
    SCREENSHOT OF VICTM’S ADDRESS BOOK
    INFORMATION FROM VICTIM’S ACCOUNT
    SCREENSHOT OF RECENT MAIL THAT YOU HAVE SENT TO THEM
    MAIL FROM VICTIM’S ACCOUNT WITH A CODE OF YOUR CHOICE (e.g. 123658)
    HIRE YOURHACKERS.COM BE AWARE OF GROWING SCAM AND FRAUD DO NOT FALL IN SCAMMERS CRAP ALWAYS ASK FOR PROOFS BEFORE YOU PAY.
    VISIT US NOW WE ARE HERE TO HELP YOU http://WWW.YOURHACKERS.COM
  32. Visit us now: http://www.crackmails.netDo you want to hack on your own? Find out how visit our website at http://www.crackmails.net100% Success hack Yahoo! Hotmail Aol Gmail etc. your hackersIf you want to hack any account in Yahoo Hotmail Gmail Aol etc. Visit us now http://www.crackmails.net We provide 100% pure satisfaction to our clients we will provide you strong proofs before you pay us We provide current original 100% working passwords Just visit us now for more information http://www.crackmails.net You will be provided with following proofs before payment, 1. Screenshot of the victim’s mailbox 2. Screenshot of victm’s address book 3. Information from victim’s account 4. Screenshot of recent mail that you have sent to them 5. Mail from victim’s account with a code of your choice (e.g. 123658) Hire crackmails.net be aware of growing scam and fraud do not fall in scammers crap always ask for proofs before you pay. Visit us now we are here to help you! Your hackersKeywordsHacking passwords, password hacking, email password hacking, hacking hotmail passwords, crack yahoo
  33. I don’t like the Google policies too. But they are a company and want to gain money. For that they must take some control.
    Anyway using an gmail account as ftp filesystem is not too fast. That is not good enought. For what you want to do that? I have all my things in my own hard disk.
    Bye.
Leave a Reply to mike m.Cancel reply
