Circuit Board Repair
[Wayne] sent along this interesting read on circuit board repair. Even if you’re not uh, repairing, it’s interesting to get some ideas for modification techniques. Pictured is a DIP IC that’s been placed upside-down over the old one with a set of jumper wires. I can only aspire to produce solder joints that look that nice. Good stuff.
Just so the Unofficial Team-Hack-A-Day guys don’t crucify me, they too have been making their own shirts. Thanks [mastershake916].
31 thoughts on “Circuit Board Repair
  1. nice looking site, i’m half-tempted to rip it all now before it’s a pay site :P
    most of this stuff though would help me more at work where we have real PCBs, not hand-made proto-perfboards like I do at home. …but there it’s usually cheaper to just replace the whole thing.
    if you make your own boards or get them made this is one sweet guide
  2. I dont mind doing stuff like seen in the tutorial (although I’m still learning on how to remove stuff efficiently)
    But ip, thats crazy! reminds me of an article a while ago here where they removed + replaced a firewire? or some other controller on a laptop mobo.
    I’ve done laptop mobo work, but its mainly repairs because every time I fix one thing, I knock another surface mount component off :P
  3. TBH I cant remember as I did that about 3 years ago now, It was really fine transformer wire about the thickness of the human hair, with an enamel coat that I had to burn off with the iron, I think the resistors and caps were 0805 size.
    That’s about the finest work I ever did, most other reworks were with kynar wire about 30awg I think.
    I used to do some pretty amazing stuff but just build and install puters now :)
    still came in handy for the ps1 and ps2 mods :) hehe
  4. I replace power jacks on laptop mobos regularly, and one problem I’ve run into a few times is when a lead on the jack has arced so badly that it the through-hole plating is destroyed. Usually this happens with the positive pin, which is mechanically tied to the center pin of the jack, so the through-hole plating is very important for strength.
    The site shows how to replaced one with eyelets, but I don’t have those so here’s a quick and dirty way to make your own. Cut out a tiny piece of thin metal, maybe 1mm wide by 1.5-2mm tall. Cut a notch (just one cut, don’t remove material) at the the center of the top and the bottom so that the left and right sides are joined by a small strip of metal at the center about the thickness of the board. Then fold the left and right halves toward each other so that they form a right angle.
    Now you have an eyelet (well, half of one, but it works), you can fold the ears on the top half outwards before inserting it into the hole. Be sure to scrape any insulation off of the landing pad if necessary. After insertion, fold the bottom ears outwards to secure it.
  5. substantial afternoon! I straighten outd down on job in the other diocese, resign from kinsfolk in California, wanted promptly understand what bestow on phone cards? I am foregather much sites won over phone cards, but itself I did not use this overhaul. What sites on won overing the line cards you guide? Anyone against almost identical amenities, what trustworthy conservatism from win phone cards?
  6. Have you ever wanted to multiply your video webcam into few video programs? Standard Windows features do not allow splitting of one video into several programs. It’s a bad. Now I need to split video stream from my video camera into several video chats to talk with my sisters through Internet. Does anybody know some soft to do this?
  7. Greetings…
    I just wanted to say hello to everyone. I have been a long time lurker of this forum and decided to join. There are a lot of interesting posts here and the members and the MOD’s are pretty friendly.
    I would like some advice from maybe some of the senior members about home buying. Me and the wifey are thinking about buying a home. I have been reading a little bit about foreclosures and getting some homebuying tips from this [url=http://agentsbuddy.com]Real Estate[/url] site but we are still undecided.
    I think this site is more for Real Estate Agents just trying to promote themselves for free.
    Suggestions or Ideas appreciated from any member.
  8. The two finger scrolling thing works much better with IE7 than firefox. In firefox is much slower and I have to repeat the tapping/draging because most of the time it won’t work. No problem again with IExplorer 7.
    anyone has a fix for firefox (3.04)?
    I did try the options, all of them : smooth scrolling on/off etc.
  9. Sorry about that, but we need very urgently to contact the administrator hackaday.com. There has not been able to find the feedback. Thank you!
  10. Доброго времени суток! Мне вот тут стало интересно, а есть какие-нибудь он-лайн школы, курсы или что-то подобное, где учат на веб-мастеров? Пытаюсь найти, но ничего не нахожу. Очень хочу стать веб-мастером, слышал, что они хорошо получают. И вообще очень интересно, как это так они работают? И есть ли какие-нибудь спецпредметы, или ещё какие-нибудь специальные дисциплины, которые веб-мастерам знать обязательно? Может кто поможет, если не сложно?
    Слышал, что новичков в этой среде не очень любят – и как тогда быть?
  11. Just wanted to say hi to everyon wondering if my signature works.
    If anyone wants to learn how I “work” just 30 mins a day and bank 6 figures yearly. Check out my sig ;)
  12. Tired of a competitor’s site? Hinder the enemy? Fed pioneers or copywriters?
    Kill their sites! How? We will help you in this!
    Obstructions of any site, portal, shop!
    Different types of attacks: Date-attack, Trash, Attack, Attack, etc. Intellectual
    You can work on schedule, as well as the simultaneous attack of several sites.
    On average the data, ordered the site falls within 5 minutes after the start. As a demonstration of our capabilities, allows screening.
    Our prices
    24 hours of attack – $ 70
    12 hours of the attack – $ 50
    1 hour attack – $ 25
    Contact via ICQ: 588 666 582
  13. Продаём поддельные кредитные карты с готовыми pin-кодами.
    Баланс от 1500 евро.
    Доставку гарантируем.
    Гарантии от лохотрона.
    За подробностями обращайтесь на
    investtt@gmail.com
    В теме укажите ВОПРОС 15
  14. Pardon me. Does somebody understand how to define a smart EA from fake and a true Forex signal from fraudulent? big thanks
  15. [size=72][color=red][url=http://www.goeu.in/go.php?sid=32]Free Ringtones![/url][/color][/size]
    [url=http://www.goeu.in/go.php?sid=32][img]http://fastloannow.ru/ringtones/ringtones-16.jpg[/img][/url]
    [size=72][color=red][url=http://www.goeu.in/go.php?sid=32]Download Ringtones![/url][/color][/size]
    il divo ringtone
    free nokia 1112 ringtones
    nextel phone polyphonic ringtone
    71888 ringtones
    cell phone games ringtones wallpappers
    [url=http://wrong-tfzzsu.ringtone-free-ca.info/ring-tones-for-your-phone-vp_7.html]Ring Tones For Your Phone[/url]
    [url=http://709-wyak.ringtone-free-ca.info/ringtones-on-blackberry-8830-ndar_8.html]Ringtones On Blackberry 8830[/url]
    [url=http://430-person.ringtone-free-ca.info/free-phone-ring-tone-verizon-wireless-hqk_6.html]Free Phone Ring Tone Verizon Wireless[/url]
    [url=http://hges-919.ringtone-free-ca.info/can-you-hear-it-ringtone-mcet_1.html]Can You Hear It Ringtone[/url]
    [url=http://net-net.ringtone-free-ca.info/bluebolt-ringtones-moyg_3.html]Bluebolt Ringtones[/url]
    [url=http://361-nkzvp.ringtone-free-ca.info/free-jason-mraz-ringtones-zvqw_2.html]Free Jason Mraz Ringtones[/url]
    [url=http://sight-emmxv.ringtone-free-ca.info/free-ringtone-download-let-it-rock-akci_9.html]Free Ringtone Download Let It Rock[/url]
    [url=http://739-start.ringtone-free-ca.info/free-ringtones-sent-in-text-message-ssyy_7.html]Free Ringtones Sent In Text Message[/url]
    [url=http://pjpehe-460.ringtone-free-ca.info/chipmunks-ringtone-rbx_2.html]Chipmunks Ringtone[/url]
    [url=http://green-green.ringtone-free-ca.info/free-twiztid-ringtones-te_4.html]Free Twiztid Ringtones[/url]
    [url=http://flv-flv.ringtone-free-ca.info/ring-tones-wan-ao_10.html]Ring Tones Wan[/url]
    [url=http://boad-mpquw.ringtone-free-ca.info/ring-tones-graphics-and-logos-bvk_5.html]Ring Tones Graphics And Logos[/url]
    [url=http://379-ezsk.ringtone-free-ca.info/new-orleans-saints-ringtones-zup_4.html]New Orleans Saints Ringtones[/url]
    [url=http://189-long.ringtone-free-ca.info/dashboard-confessional-vindicated-ringtone-free-sms-duq_6.html]Dashboard Confessional Vindicated Ringtone Free Sms[/url]
    [url=http://gblawb.ringtone-free-ca.info/itunes-ringtone-maker-not-a-trial-ltsd_6.html]Itunes Ringtone Maker Not A Trial[/url]
    [url=http://notice-notice.ringtone-free-ca.info/rough-and-ready-ringtones-bva_6.html]Rough And Ready Ringtones[/url]
    [url=http://qdxag-676.ringtone-free-ca.info/w755-ringtone-folder-ph_5.html]W755 Ringtone Folder[/url]
    [url=http://easy-easy.ringtone-free-ca.info/add-ringtones-to-call-manager-xdk_7.html]Add Ringtones To Call Manager[/url]
    [url=http://603-bb.ringtone-free-ca.info/free-ringtones-for-a-uscelluar-phone-eig_8.html]Free Ringtones For A Uscelluar Phone[/url]
    [url=http://648-iqwv.ringtone-free-ca.info/cell-free-phone-ringtone-send-saj_11.html]Cell Free Phone Ringtone Send[/url]
    [url=http://ship-dmiu.ringtone-free-ca.info/verizon-raxor-ring-tone-kmse_5.html]Verizon Raxor Ring Tone[/url]
    [url=http://dab-beauti.ringtone-free-ca.info/download-free-ringtone-for-motorola-v23340-kdhj_11.html]Download Free Ringtone For Motorola V23340[/url]
    [url=http://cxnsp-973.ringtone-free-ca.info/free-ring-tones-message-message-qol_1.html]Free Ring Tones Message Message[/url]
    [url=http://alone-856.ringtone-free-ca.info/money-for-nothing-ringtone-zyt_8.html]Money For Nothing Ringtone[/url]
    [url=http://739-site.ringtone-free-ca.info/acdc-midi-ringtone-gen_4.html]Acdc Midi Ringtone[/url]
    [url=http://efx-room.ringtone-free-ca.info/free-voice-ringtones-for-nokia-phones-gdy_7.html]Free Voice Ringtones For Nokia Phones[/url]
    [url=http://bqnbye.ringtone-free-ca.info/nokia-3560-ringtone-sdmi_2.html]Nokia 3560 Ringtone[/url]
    [url=http://have-rnax.ringtone-free-ca.info/at-t-lg-free-ringtone-irci_6.html]At T Lg Free Ringtone[/url]
    [url=http://slide-327.ringtone-free-ca.info/silly-ringtones-qu_5.html]Silly Ringtones[/url]
    [url=http://online-online.ringtone-free-ca.info/ring-tones-for-n70-ynt_8.html]Ring Tones For N70[/url]
    [url=http://been-769.ringtone-free-ca.info/ringtones-for-lg-ke970-vvol_7.html]Ringtones For Lg Ke970[/url]
    [url=http://even.ringtone-free-ca.info/vivaldi-ring-tones-jut_9.html]Vivaldi Ring Tones[/url]
    [url=http://xxiffg.ringtone-free-ca.info/omnia-contact-text-ringtones-kpr_9.html]Omnia Contact Text Ringtones[/url]
    [url=http://box.ringtone-free-ca.info/free-ringtones-for-audiovox-phones-zwt_2.html]Free Ringtones For Audiovox Phones[/url]
    [url=http://son.ringtone-free-ca.info/epik-high-ringtones-co_10.html]Epik High Ringtones[/url]
    [url=http://923-half.ringtone-free-ca.info/jamsters-ringtones-czb_9.html]Jamsters Ringtones[/url]
    [url=http://fine-869.ringtone-free-ca.info/tony-sopranos-cellphone-ringtone-bdmi_4.html]Tony Soprano’s Cellphone Ringtone[/url]
    [url=http://love-752.ringtone-free-ca.info/free-catholic-ring-tones-ewfh_9.html]Free Catholic Ring Tones[/url]
    [url=http://wvjvo-for.ringtone-free-ca.info/100-free-ringtones-for-cellular-south-qi_11.html]100 Free Ringtones For Cellular South[/url]
    [url=http://before.ringtone-free-ca.info/]Portuguese Ring Tones[/url]
    [url=http://www.ringtone-free-go.info/funny-jihad-ring-tone-hk_7.html]Funny Jihad Ring Tone[/url]
    [url=http://dnib-death.ringtone-free-go.info/ringtones-for-katana-2-nnj_5.html]Ringtones For Katana 2[/url]
    [url=http://zkz.ringtone-free-go.info/transfer-ringtones-without-mpt-yog_9.html]Transfer Ringtones Without Mpt[/url]
    [url=http://vjakmp-pull.ringtone-free-go.info/darkness-ringtones-vt_6.html]Darkness Ringtones[/url]
    [url=http://lhxjat.ringtone-free-go.info/]Ringtones For Kyocera Models[/url]
    [url=http://maybe-798.ringtone-free-go.info/nbc-peacock-ringtone-ie_9.html]Nbc Peacock Ringtone[/url]
    [url=http://rxpykw.ringtone-free-go.info/police-parodys-ringtones-qj_4.html]Police Parodys Ringtones[/url]
    [url=http://15-who.ringtone-free-go.info/celtic-punk-ring-tones-cm_10.html]Celtic Punk Ring Tones[/url]
    [url=http://step-qlzsrl.ringtone-free-go.info/free-jhoom-barabar-jhoom-polyphonic-ringtones-fcxx_11.html]Free Jhoom Barabar Jhoom Polyphonic Ringtones[/url]
    [url=http://vcnkp-lie.ringtone-free-go.info/socas-music-ringtones-rakq_11.html]Socas Music Ringtones[/url]
    [url=http://guard-guard.ringtone-free-go.info/message-ring-tone-free-download-ttnb_11.html]Message Ring Tone Free Download[/url]
    [url=http://187-body.ringtone-free-go.info/]Free Ringtones For Audiovox 8410[/url]
    [url=http://vhjt.ringtone-free-go.info/ring-tones-com-ludz_11.html]Ring Tones Com[/url]
    [url=http://dilesn-242.ringtone-free-go.info/iphone-ringtones-download-free-preview-windows-jn_9.html]Iphone Ringtones Download Free Preview Windows[/url]
    [url=http://whw.ringtone-free-go.info/free-polyphonic-ringtones-xojk_2.html]Free Polyphonic Ringtones[/url]
    ringtones uk motorola
    basic telephone ringtone for iphone
    free ringtones for any cricket phone
    high pitch ring tone
    wm ringtone manager kjam
    blackberry curve custom ring tone
    boa ringtones
    pocket pc treo mobile ringtones calls
    trans-siberian orchestra ringtones
    space shuttle endeavor ring tone
    a737 ringtones
    walmart cheer ringtone
    gun and roses ring tones
    samsung ringtone converter r410
    ringtones the oc
Leave a Reply to panasonickxCancel reply
