Pandora’s Battery (unbrick Your PSP)
[krazywhiteguy310] let me know about the announcement of the Pandora battery hack. It’ll cost you a Sony PSP battery to pull off the hack, but once you’re done, you can use it to jump start your bricked PSP to load up a memory imaged designed to unbrick the PSP. (I haven’t tested it, so I’m taking this on faith) Excellent news if you’ve bricked your PSP.
124 thoughts on “Pandora’s Battery (unbrick Your PSP)
  1. Hi, my son’s psp 2001 won’t work and we tried the pandora battery and magic sd card but nothing is happening. Has anyone got that to fix theirs?? Please help!!
    Thanks
  2. pls help me how to unbrick my psp 3000 when im playing iso/cso games it hanged when i turn it on i see in my screen is non help me pls!!![sorry for my english]
  3. Hi,
    My psp 1000 just bricked while upgrading to Gen-D3. Its an original 1.50 firmware. Can i unbrick it with a Pandora battery ONLY just back to original 1.50 or do you need the magic memory stick aswell to set it back to this or other custom firmware versions?
    Can this be done with battery only booting psp up to recovery mode?
    Many thanks in advance.
  4. i buy psp model 3004 version5.03 and there i tape inside of it, and when play it require to down load the soft ware, so i did it.my psp version 5.03 was upgraded to 5.50 version all the in memory stick has been lost, i can not play any more games with my psp, what will i do with my psp now?
  5. hello i got a problem i got a slim pandora battery and a 1GB mms.i had installed CFW to my psp and now i changed it to OFW.is there any way to change it back to CFW?when i try to insert the pandora batt it automatically turns the power green then turns back off…please help ASAP.
  6. Hey ppl I was wondering if i could use a pandora and mms to install 5.50 GEN-D3 directly onto my psp. I heard that u have to install 3.71 m33 and then follow an update path.
    Is this true, or can i put GEN on my psp 1001 w/ 6.20 OFW?
    Thx ppl
    BTW i am $5.00 away from pandora online =)
  7. The Pandora battery is sinple to make. I can personally testify if you make a Pandora Battery you can still “Charge” your Battery and use it for normal use. The Pandora Battery doesnt brake the battery unless the maker of the battery screws up. Easy instructions online. I have tried this on a Slim and A Fat 1, 2, 3k
  8. WILL THE VERSION DOWNGRADED WITH HELP OF PANDORA BATTERY WILL BE REMOVED ONCE I EJECT MY PNDORA BATTERY AND INSERT A NORMAL BATTERY
  9. Yup. The Pandora Battery will replace the PSP’s internal flash memory with that of hacked PSP. Kinda like installing a sony update, but a HACKED update.
  10. Hi I have a PSP 3004 with Firmware version 6.20 I need to Know. Can I Downgrade this with the Pandora Battery. and If I mess up will I be able to recover to any version of firmware OFW or CFW.
    I read a lot of post all over the internet. but most of them is very old. This is the first site that seems to have recent posts.
  11. everybody listen there is NO WAY possible to unbrick a fully bricked PSP 3000 and most likely NEVER will be. SO QUIT SCREWING WITH FLASH0!!
