I’m not usually into products, but I like this one. Remember this diy SDI DVD video out mod which lets you send high quality digital video over coax? Thanks to Pixel Magic, you can mod a variety of DVD players to add SDI thanks to the kit they’re offering. At a glance, bt.656 and bt.601 appear pretty similar, but the eval kit from the original only claims to be compatible with bt.601 while the Pixel Magic version is for bt.656.
7 thoughts on “SDI Mod Your DVD Player”
Looks great, but can it use the audio from the MPEG stream and embed it into the SDI stream as AES?
Not much use if it can’t?
Nice Idea, and I actually could use this application – however PixMagic charges $150.00 for this little bugger. Is this really worth it? Can’t I buy a DVD with coax already or is the quality worth that price?
You tell me
as with the original post, i’m curious what displays accept an SDI input? if this is supposed to be a cheap solution for SDI, wouldn’t we still need a capture device or some high end display? am i missing something?? i found SDI to DVI-D adapters… would this type of mod allow for very long cable runs? might be worth the $$$ in that case.
I think this is more about putting an SDI card in a PC and capturing the decrypted and decoded data stream. Sure, you’ll need to reencode it if you want to save it in a compressed format on your machine (and that’s a lossy step) but it renders any tricky encryption or other content protection schemes irrelevant.
Now if they can get me an HDSDI mod for a blu-ray player, I would be in heaven…
if this mod is for HD-SDI output, the reason for the mod is that HD-SDI is superior to HDMI in that “with HDMI you’re at the mercy of how well the devices’ HDMI implementation is, With HD-SDI you’re guaranteed to get the untampered with video stream out of the device”
http://www.avsforum.com/avs-vb/archive/index.php/t-700791.html
