[Ray] noted that spectrum analyzers have become a favorite project for FPGA evaluators and sent in his groups version from 2004. His team used a combination of MatLab, an Altera FPGA and sixteen pumps to produce real-time sound spectrum output.
9 thoughts on “H2O Spectrum Analyser”
Leave a Reply to RayCancel reply
the effect is less than desirable due to water physics
my fave remains the flaming spectrum analyzer
http://www.youtube.com/watch?v=RyIphO4Ypoo
rich: this can be totally negated by playing the music with a slight delay, with regard to the analyzer. I think it’s a dope idea.
yeah… as long as the “source” isn’t live there’s no reason that the audio output can’t be delayed to sync up with “water physics”
@rich:
except for the fact that the flame one isn’t really a spectrum analyzer
why not solenoid valves instead of 16 pumps?
he should give each pump its own reservoir with differently colored water in each
It’s the Bellagio, writ small… very cool.
yeah delay idea would definitely help but it doesn’t change the fact that water falls at a fixed rate (too slow) that you can never change.
i was thinking about this thing today and i think that you could tinker with nozzles and pressure ranges to achieve something less sloppy tho.
if anything, i think that this rig could be reincarnated as something other than a spectrum analyzer to great effect.
alas, ’tis true that the flame scope is not a spectrum analyzer at all. i love how simple it is tho. plus, FIRE. =D
Originally we wanted to use solenoids but the ones we wanted were $40-50 each and that added up quickly. We were also concerned that they may be very loud.
Some of the delay is due to the capture time within Matlab. It had to sample for a brief window, process the FFT, and then send the data to the FPGA to generate the PWM signals. If we could’ve sent an audio signal straight into the FPGA through an A/D and processed an FFT there it would have been much quicker.
