Turn Signal Jacket How-to
[Leah Buechley], whose work we’ve been covering since way back when, has built this lovely turn signal jacket. The project photos were posted in March, but she’s just added a well illustrated project guide. The jacket is based around a LilyPad Arduino, a lightweight Arduino board with radial pads designed to be used in wearable projects. You make your connections by sewing conductive thread through the pads. The how-to covers attaching the LilyPad parts properly and then insulating the wires with fabric paint after you’ve verified they work.
The guide has an interesting discussion about placing the power supply. The 4-ply silver coated thread used has a resistance of approximately 14ohms/foot. So, if you place the power supply one foot from the LilyPad, the two wires combine for 28ohms, causing a 1.4V drop. The power supply is only 5V, which means the LilyPad will be 3.6V. A voltage of 3.3V will cause the Arduino to reset. If your resistance is too high, you’ll have to add more thread.
The power supply on this jacket is under the collar. Each cuff has a single button plus an LED. The button will make the jacket flash the direction for 15 seconds (also indicated on the sleeve LED). If you press both buttons at the same time, it switches to night mode by flashing both directions at the same time to make you more visible.
2 thoughts on “Turn Signal Jacket How-to
  1. neet hack. though I would recommend using RED yellow or orange LEDs to keep in compliance with the traffic laws of most states.
    White is reserved for headlights and reverse lamps, lights with elements of blue (blue, green, purple, etc.) are typically illegal as they’re reserved for police vehicles.
  2. Dear Sir/Madam,
    We are certified loan lender.We offer secured loans to individuals and companies at low interest rate.I offer long and short term loans.Our firm has recorded a lot of breakthroughs in the provision of first class financial services to our clients especially in the area of Loan syndication and capital provision for individuals and companies.
    We have brought TAavinton industries is back to life and we back for good business ideas by providing funds for their upstart. We have a network of Investors that are willing to provide funds of whatever amount discreetly to individuals and organizations to start business and operations. We also recruit Agents to assist our client companies to receive payments for their goods and services. In our bid to be useful to you, please tell us which area that you wish us to be of service to you. Kindly respond immediately to this email: tavintonmcguire22.com
    after we shall speak
    Looking forward to your reply.
    Truly yours,
    Mr Tavinton.
Leave a Reply to twistedsymphony Cancel reply
