[eric] has found that he can build a pretty nice 2 axis joystick out of some VCR parts. Specifically, he’s using the idler wheel. When you disassemble the idler wheel, you’ll find that it has a bevelled washer in the perfect location to help with smooth joystick operation. Add a spring and a hole in some wood and you’ve got the basics. All you need to add now are the switches. This is a fantastic example of recycling parts, you never would have guessed that it was made from trash.
