Fedora Rawhide Nightly Builds
fedora_rawhide
The devs over at the Fedora Project are hard at work on the development version: Rawhide. They’ve just setup automated nightly builds of the liveCD which can easily be downloaded and tested on a CD, DVD, USB drive, virtual machine, or separate partition.
Rawhide will be released as Fedora 12 upon completion.  With this version you have a choice of Gnome 2.28 or KDE 4.3 for your desktop.  There is also improved power management, expanded support for mobile broadband, easy bug reporting, and many more new or improved features. So roll up your sleeves, download last night’s build, and help test some open source software.
[via Download Squad]
12 thoughts on “Fedora Rawhide Nightly Builds
  1. try running FC11 in runmode 3 or on a box with an AGP HD 3xxx vid card… or…
    in runmode 3 (multiuser console) you get message dumps from the network that garble up whatever the hell you’re typing or viewing. It also doesn’t show you the boot-up process in console mode so you can’t check what started and what didn’t without checking all the pids and runs and locks. if it weren’t for the fact that I rarely reboot/modify that system, I would have gone back to FC10 immediately. and there’s also the problem with all the forums I’ve ever visited about the network message dump issue never responding to any posts. it seems nobody cares about those of us who don’t like starting a headless system in graphics mode since it make absolutely no sense at all.
  2. i haven’t had any major (<1hr of googling to find solution that actually works) network issues. occassionally (like now) an update will happen and my minimize, maximize, and close buttons (with associate bar) will go missing.
    my biggest issue was digging and waiting ~1 MONTH for solution to get the computer boot after the move from fc10 to fc11 because it would break any computer that uses RAID of scsi. with my digging, i found this same exact problem crops up ever so often AND the developers of fedora knew full well (discussions at bugzilla) that this would happen if they allowed fedora 11 to be release as is.
Leave a Reply to deepangel Cancel reply
