Turntable Sequencer Scratches With Coins
scratching-with-arduino
[tvst] has an interesting take on a sequencer. His design uses coins on a turn table to trigger midi events in a loop. There are four tracks available, each having its own sensor above the spinning platform. The sensors consist of an IR transmitter and receiver setup as a voltage divider. When something passes below the IR transmitter and reflects the infrared waves back up to the receiver, the output of the sensor moves to digital high. The four sensors are connected to an Arduino which is used in conjunction with ttymidi, which converts the Arduino data into midi events.
We like projects that provide a more tangible interface for the user. Coins work well for this setup. They reflect infrared enough to trigger the sensors, and they’re easy to pick up and move without upsetting the rest of the tracks. It would be great if this could be expanded to differentiate between coins (pennies versus dimes, etc.) in order to increase the resolution from four different events to eight or more. Check out the video after the break.[youtube=http://www.youtube.com/watch?v=IXOQISfoRks]
10 thoughts on “Turntable Sequencer Scratches With Coins
  1. The turntable should be divided in such a way that it can show a measure of music. It would be easier to get precise times for a good loop.
  2. @Wraith he is spinning the turntable himself though, so the measure could be 1 revolution, or 1/2 or 3 or any number of revolutions depending on the speed he is turning the turntable, and the tempo of the song.
Leave a Reply to craigCancel reply
