Mindstorm Rubik’s Solver
It has been quite a while since we looked in on the world of automated Rubik’s cube solving. [David Gilday] built this one using LEGO Mindstorm parts. It uses a computer to calculate the solutions but unlike the standalone Tilted Twister, this creation can solve more than one type of cube. As long as the physical dimensions are between 5 and 6 centimeters on a side, the machine can solve 2, 3, 4, and 5 piece cubes. [David] wasn’t quite satisfied with that though. He built a separate machine to take care of the 6x6x6 cubes too. See both in action after the break.
Want to see more? Don’t miss the CuBear solver developed at Berkeley or the AVR based solver.
[Thanks Pieter via Singularity Hub]
14 thoughts on “Mindstorm Rubik’s Solver
  1. I just had a pie in the sky idea to try to build a rubik’s cube where the electronics to move the pieces are internally contained and it solves itself without visible connection to anything.
  2. The one thing dorkier (notice how I didn’t say nerdier) than playing with rubiks cubes – using lego blocks to solve them. This is a cool project and all but the people who play with rubiks cubes are almost universally douchebags.
  3. good luck matt, dont know if you have pulled one apart but unless you make it huge the space constraints would make this difficult, but never the less would love to see it on HAD one day.
    also kirov well done on the hating/trolling as usual.
  4. Lego nullifies it a lot. Lego is in general pretty dorky but far less annoying. It is the type of people who walk around with rubiks cubes solving them in public, acting like memorizing algorithms is an accomplishment and deserves your attention that make most things involving rubiks cubes sketchy. Lego alleviates some of this as you are actually building and creating something rather than just being a hipster-geek trend whore, and the two cancel out a bit.
  5. the “pie in the sky” idea to build a self solving cube could open a perfect excuse to play with some nitinol. By applying electricity you could manipulate the temperature of the material and get some movement out of it. Just a thought.
  6. Well, the simplest self-solving cube would be one with 6 LCD’s on the sides, that simulate rotation by swapping colors :) I might build one, but I only have 5 identical LCD’s :(
    So 6 nokia screens, one microcontroller (maybe 6 resistive touch-screens to allow for user interaction) and you have a new toy :D
  7. @Fili: something similar already exists, though the implementation details are a bit different. It’s called the Rubik’s Touchcube: http://www.rubikstouchcube.com/
    If you’re looking to buy one, shop around a bit for sales – prices vary from $50 (Best Buy on sale) to $200 (F.A.O. Schwarz).
    It takes some getting used to because an internal accelerometer only activates the top face to prevent spurious manipulations by the fingers holding the cube.
  8. Hi, im teaching a class about Lego Mindstorm and i already taught them how to use all the censors. there are two more 3 hour classes and i want to do a competition and declare a class champion. what should i have them do? something like an obstacle course would be nice but i don’t know what to have in it. im open to other ideas though.
Leave a Reply to mrgoogfan Cancel reply
