I went to the last monthly meeting of Sector 67, a hackerspace in Madison, WI. One of the things shown off was a color changing LED light bulb that Menards was clearing out for $1.99. Inside there’s two RGB LEDs controlled by an ATtiny13 and powered by an AC/DC buck converter. An ATtiny13 will run you around $1.25 by itself so this price is quite amazing. I grabbed a couple of these bulbs and set to work on them. Join me after the break to see what I’ve got so far.
Update:Â read a follow-up to this post.
These bulbs use a candelabra base so I grabbed an adapter and tried it out in a lamp. Here’s the result, you can see it stepping through color levels a few times a second:
[youtube=http://www.youtube.com/watch?v=yRrYp3qRBXc&w=470]
We’ve seen this in a lot of mood light hacks, I want to get at the hardware and make it do my bidding. First thing’s first, time to crack it open. For some reason I thought that carefully drilling some holes around the base would help me figure out where best to use the Dremel cutting wheel. Unfortunately I immediately drilled through one of the inductor coils. Drat.
Well, no stopping now. I’m not too worried as I also bought a solid red version of this bulb. I want to see what’s inside, whether it’s the same design with unpopulated components, or the full shebang with different hardware. I assume there’s no microcontroller inside so I’ll steal the inductor from that one later.
I cut off the diffuser and got to the circuit board. Here’s some images (click for hi-res) as well as a cursory list of hardware.
Top:
- R2 – 1004
- R3 – 1004
- R4 – 3001
- R5 – 1302
- R10 – 1003
- D4 – Looks like a zener… perhaps to set down votage for the tiny13
- D5 – RGB LED
- D6 – RGB LED
- D7 – JF S1J
- IC5 – ATtiny13
- C1 – smd without label
- C7- smd without label
Bottom:
- R1 – inline with center conductor of light socket
- P1 & P2 – Labels for incoming AC power?
- L1 – 102J CEC
- L2 – 102J CEC
- C2 – 50V 22 uF electrolytic
- C3 – 400V 4.7 uF electrolytic
- C4 – 400V 4.7 uF electrolytic
- C5 – 25V 100 uF electrolytic
- C6 – smd without label
- D3 – R106 TF
- R6 – 1201
- R7 – 1Bx
- R8 – 270
- R9 – 270
- IC1 – NGSÂ (transistor for driving LEDs?)
- IC2 – NGSÂ (transistor for driving LEDs?)
- IC3 – NGS (transistor for driving LEDs?)
- IC4 – LNK304GN AC/DC switching converter
I wanted to see if I could talk to the ATtiny13 so I soldered wires onto the pins and hooked it up to my AVR Dragon programmer. ISP was a no go so I soldered more wire to the remaining connection and gave high voltage programming a shot. That was also a failure. But since I already hosed that inductor I have no issue popping the microprocessor off of the board. Here it is soldered onto some perfboard and inserted in a breadboard:
I tried ISP again and that was a no-go. But this time around High Voltage Serial Programming worked. I talked to the chip with AVRdude using this command:
avrdude -P usb -p t13 -c dragon_hvsp -v
That polls the chip and reads back the fuse settings. Currently the lfuse is 0x6A which is the factory default but the hfuse is 0xFA. After checking the datasheet I see that they’ve disabled the reset function (that’s why ISP doesn’t work) and enabled brownout detection. I dumped the firmware and the eeprom and that’s where I’m at. Now I need your help.
I haven’t done much reverse engineering before this so I’m not sure what to do next. I disassembled the firmware using ‘ndisasm’ but I have no idea what I can learn from it, or even how to read it. I’d love some help answering two questions:
1) Why couldn’t I talk to the chip when it was on the circuit board?
2) What can I learn from the disassembled code. Update: after running the code through an AVR disassembler it looks like this is just an ascending list of numbers. [Tiago] pointed out in the comments that this is the behavior when the lock bits have been set. It should be possible to reuse the chip by erasing it but I won’t be able to dump the firmware first. Now I’ll focus on figuring out how the board is routed.
Let me know in the comments.
Be careful. Harmful / toxic substance are inside the bulb, as mercury, etc.
Angelo… no.
Angelo, are you sure you’re not thinking of CFLs? I wasn’t aware of LED presenting a mercury hazard
1. Was the programmer soldered directly to the pins? Maybe there’s a regulator of some sort dropping the HV signal. O’Scope it.
2. Looks like a lot of “add” in the code and not much control logic. I suppose it’s just running a simple loop cycling through colors though. Maybe the adds are an obfuscated way to go about setting up all the I/O registers, etc. Not sure. Wish the disassembler would’ve filled in register names like some others do…
That’s my quick first look.
It looks like you didn’t actually get the code read from the device.
All you’ve got is an incrementing data pattern. See it count 00 01 02 03 04? That’s it.
So I would try again to read the code from the chip and then disassemble it.
And There’s no mercury in LED bulbs, so you’re safe.
@Angelo
Check your facts. You’re clearly mistaking LED bulbs for CFL bulbs (the coily ones)
@Goldscott:
1. Yes, soldered directly to the pins. Unfortunately I don’t have a scope.
2. Anyone know of a better disassembler to use than ndisasm?
This code looks x86 to me, not AVR assembler. Could you either put up the .bin file or disassemble it using avr disassembler?
The converter’s trying to draw too much current, more than your ISP can provide, which is why you couldn’t talk to it in circuit. We see the same problem in the adafruit Ice Tube Clock kit when you attempt to program the ATMega ISP with the tube plugged it. Cut the leads (Vin0 to the buck converter and you might be able to program it in circuit. But since you’ve pulled it it hardly matters at this point.
Oh, and there’s not much toxic substances in an LED, Angelo. It’s not a CFL.
The disassembled code doesn’t look correct. It’s just 0x00-0xFF twice, interpreted as assembly. I know some AVR devices can protect their code space from being read for security, is the Tiny13 one of those devices?
begone mercury scare monger.
also: your disassembly isn’t of the firmware. note that the undisassembled code is just a couple of regular numeric sequences, e.g. 1, 2, 3, 4…
Code looks funny because ndisasm is for intel architecture and not avr, no?
I would say you could not talk to the AVR in circuit because the pins are obviously connected to other components on the PCB. That introduces loads to the pins of the AVR and the programmer, so the signal gets altered, distorted, weakened..
Sometimes it’s possible with a very slow programming speed.
I don’t think you used the right disasmbler, or atleast it in a correct way. Can you post the raw flash/eeprom files?
The dump is just the word values 0000 to 00FF, translated to x86 16 bit mode opcodes? Because that looks nothing like AVR ASM.
That’s just an incrementing patter. It doesn’t look like the code download worked.
(avr-objdump from winavr can disasmble)
alankilian is right–that ain’t code you have there. I’d be willing to take a look at the real code once/if we get it. For something as simple as a color-cycling bulb, it won’t be very complex.
Be careful. Eating the LED’s can be harmful! :P
Seriously though, nice teardown and good job getting the at the code!
I’d have to question the value in reverse engineering the code – you’ve got a set of clearly defined inputs and outputs, and it’s easy to infer what is going on in the uP. It’s normally only really necessary to reverse engineer more complex system.
Perhaps later I’ll take a look at the code. But right off I’m thinking “danger, 110V!”. Then it strikes me. These things are $2 each! Buy two. Make one into the power supply then the other into the development / hacking platform.
If I had to guess w/o looking I would say the software is probably an exercise in pulse width modulation. Such that you can slowly change the colors of the LEDs.
You pictures are very good. I can see each LED has 6 legs. And there appears to be 3 LEDs (dark spots) in each LED case. If you can trace these back to the micro (probably through a transistor like device) that should help others backwards engineer the code.
I can think of some great fun with these. I remember internet connected devices which changed color based on scraping the weather or stock market reports.
What would help is a quick check and sketch of the LEDs leads, how they are powered and from which pin of the micro. That way we could look at the code with an eye of understanding. If the
Yup, definitely unsafe. I hear they also contain roentgenium and Darmstadtium, which is probably why they don’t last very long. Oh, and the case is made from asbestos. Better look out for the velociraptors hiding in the box, as well!
I agree about the ASM code dump, it does not read like real code, I don’t think it converted correctly. I see nothing that indicates a control loop of some sort. post the raw dump
You can’t talk to the chip while it was on the board because HV programming isn’t designed to work in-circuit. ISP doesn’t automatically work in circuit either unless the board is properly designed for it. They probably had the attinys pre-programmed before they assembled the boards as is usual in production at this scale.
Can you tell if the reset pin is connected to anything on the board? They may have disabled reset as a rudimentary protection measure or more likely they may have needed to repurpose the pin for another purpose.
The AC->DC converter on the lower part of the board outputs 12V. Undoubtedly the LEDs are driven at 12V by the transistors/FETs on the underside. There is some possibility that the ATtiny is both controlling the LEDs and playing a part in the power supply. Before having a look at the code it would be useful to know something about where the IO pins of the ATTiny are routed.
It probably wouldn’t even be worth trying to wade though the disassembly if the mcu is simply controlling the LEDs. Theres plenty of code out there for that — it would be easier to simply write your own implementation. If it’s playing a part in the power supply though, things are going to be far more complicated.
I have 2 questions.
1. Why do you try to disassemble ATTiny assemble code with x86 disassembler?
2. Why do you try to disassemble 00 01 02 03 which does not look like processor instructions? Processor instructions are likely to be more “irregular”.
I would find where they start, find proper disassembler, and try again.
I don’t have an answer to your first question and an partial answer to the second one.
You can learn a lot form the code in the microcontroller. It can teach you how the device works. Unfortunately, the disassembled code you posted is useless. You used nsisasm, which is a 80×86 disassembler and therefore incapable of understanding avr binary files. Try using an avr disassembler like vAVRdisasm. You’ll see that
the produced code will make more sense.
Once you understand how the code works, you can modify it to suit your needs. You can for example make it to display different color sequences or blinking patters. Those are just some ideas.
If the protectio bits are enable everything that you will read is the flash address and not the flash contents, as said, learn how to use avr-objdump, because its pretty obvious that your disassembly is from a x86 core, those have AX,BX,CX,DX,SI,and others registers, AVR’s have r0,r1,r2, up to r31 and then they have the X,Y and Z for the pointers.
If you disable the reset, you cannot use ISP. The device looks like it is protected against reading the code(which is how most micros are in commercial aplications in order to protect duplication). Still, it should be easy to reproduce. Also, get a new bulb and hook up a scope on each of the pins.
Hv programming is not suited for in board and it might even damage other parts of the circuit.
I wish i could find such cheap bulbs… now attiny13 costs more than $2 for one piece.
@Angelo, +1 internets for successful troll.
You need to reverse engineer the schematic.
Use generic component pinouts for LEDs & transistors.
I wouldn’t waste any time on rev.engineering the firmware. 3ch PWM control is not a big deal.
For debugging don’t use live Voltage, inject 12V after the PSU, it will be much safer after that (it might damage the PSU).
After finished that, you can think about controlling the bulb. (NO direct connections!)
Only wireless: IR,RF,sound
Make it IR remote controllable, like the Philips bulbs.
Place many in one room, average the colors of your monitor/screen, then make dynamic ambient light.
That’s all you can do for $2.
Dude, get a girl!
Would you please make the binary (or hex) file available to us. Then one of us could feed it into IDA Pro or any other modern analysis tool ;)
Angelo, your thinking CFL, Led has no toxins, well the plastic / metal isn’t health to ingest, but it lead / mercury / gas free….
Switching buck regulator + some nmos FETs to PWM the LEDs + shunt regulator for the ATTiny. Not terribly efficient, but this is mood lighting and not illumination.
The 270 ohm resistors seem a bit high if they’re limiting LED current, but we don’t know for sure what voltage the buck regulator is generating.
Nice little light for $1.99, wish I had a few to hack on. :)
@Donov4n
Which dude?
They all could use one — or more!
R4/R5 are feedback resistor divider for buck regulator, which with the feedback voltage of 1.65v from the datasheet gives an output voltage of ~9v.
R7/R8/R9 are the current limiting resistors, which the original post read incorrectly – looks like 18, 22, and 27 ohms. guesstimate 150 mA per LED die? that seems high still, but not ridiculous.
Only $1.99? And I got my IR controlled one for like $30. Feel like a sap now. Ah well. Looking forward to the development of this project, maybe then I can add IR to a bunch of these and have a whole bunch running off of one remote.
i rember back in the dishnet hackign days on some 301 irds having to cut a trace that was holdign the reset pin of the tsop low to be able to gain read/write access.. i would be intrested to see what the pins on the atiny are tied to.
Yeah I think the mercury thing was some spammer and it’s all over now but mercury scare?
Mercury’s fun! Just play outside :p
Nice work on this, shame I have not seen anything similar in the UK, would be a nice thing to hack up.
Awesome to see people hitting up Sector67. I’m gonna have to stop by late December when I’m back up there.
Tiago mentioned that the lock bits might be just feeding the register addresses when read. I think he’s right because I tried disassembly with vAVRdisasm and I get sequential numbers. The debugWire is not enabled so it looks like there’s no way to dump the code.
I’ll need to try and figure out how the board is wired up. I’ve done some continuity testing but no success if tracing from uC pins to transistors, or figuring out how the LEDs are connected. Bit of strangeness going on that I’ll have to look into more this weekend.
Can read out every page of EEPROM and FLASH even with the bits and fuses set using a buffer/reset trick ^^
BTW I think they officially support rewriting to both, but only after chip erase is called, and after reset. Read about watchdog and the buffer-before-erase method to get data out on the 1-wire pin.
If you want I can give you working code for the arduino IDE that uses an HSL colour wheel and then translates the Hue value to RGB and output that as pwm for an RGB led, but its very very easy to do, and there are many examples out there.
Fell free to ask.
@xorpunk
Could you provide some details on the buffer/reset trick? I took a look at the datasheet and didn’t see what you meant. I’m curious…
Hey Angelo, no worries – I glanced at original post and thought exactly the same as you till I saw the pix of the *plastic* bulb – yep, DUH :)
Just looking at looking at CFL circuits for first time- interesting, but a bit Hairy-Scary / incomprehensible for me – (soon as it gets into Coils/Inductors am a bit lost…)
Any interesting hacks with CFLs/’CFL bases’ (i.e. sans bulb) out there? I keep getting packs of them sent to me for free from my electricity supplier, but I don’t like the light they give out so they just sit in my cupboard.
http://www.pavouk.org/hw/lamp/en_index.html#electrical_construction
yeah you take a cfl base and hook it up to a tv’s flyback transformer and make a lightning machine. i don’t remember exactly what you hook where, google it. http://www.youtube.com/watch?v=hHsxnbCQCww&feature=related
this guy’s gaps are better: http://www.youtube.com/watch?v=9pd1w63gaU4
when i originally read the cfl+flyback thing, i thought it said you could make like really long ‘lightning bolts” like a few feet long.. i love it when a cfl burns out. burnt out incandescents are practically useless, but a dead cfl brings something to the table
Looks like a fairly strait forward circuit to me. The LinkSwitch LNK304 universal off-line switch mode controller is a class of devices found a lot in the smaller wall adapters for cell phones and the like. That particular chip can only output about 170mA of total current due to the limitations of the internal switching FET. It probably just provides the board with regulated 5V, based on the requirements of the ATtiny and the fact that I don’t see another voltage regulator. Although it might be possible that D4 is a zener and is being used as a rudimentary regulator for the AVR.
Throw in a few FETs as low side switches to PWM dim the RGB channels of LEDs and you have yourself a mood light!
LOL@not seeing the no read pattern and THEN trying to use an x86 disassembler on it.
