DIY Clapper
[Patrick’s] latest Instructable walks us though making a clap clap on / clap clap off type of switching circuit, similar in use to that sometimes popular commercial product seen on TV. He does this by using a standard electret microphone, half of an LM324 op amp, a voltage comparator and a PIC micro controller.
The operation of the device is as simple as its wiring, the microphone picks up sound and produces a signal, that signal is stripped of its DC component and fed into the op amp, after 2 stages of amplification the signal passes though a voltage comparator, and if the sound was loud enough a timer is triggered on the pic. Two claps within the specified amount of time, the micro then switches on a relay which can toggle your outside appliance (keeping the load in mind).
On the last page [Patrick] also gives a rough outline of how to make a single clap on / off variant using a 555 timer and some flip flops. Join us for a quick video after the break, and be sure to check this one out.
11 thoughts on “DIY Clapper
  1. @swighton
    “””the micro then switches on a relay which can toggle your outside appliance”””
    You could also easily make a double clap with a 555 also… just use a 555 monovibrator triggered on the falling edge of the clap signal to define the valid length after a clap, then AND it with the clap signal.
  2. My son and I made something almost exactly like this for an “invention fair” last year. His idea was to turn a light switch on when his alarm went off, but in the end, we realized that we’d just re-invented the clapper. Jonathan is right — the double clap can be achieved without a microprocessor. Our needs were simpler — one audio trigger, but a delay before another signal was allowed in. So, dual 555 chips (single 556 really), and some logic gates. Not 555 contest-worthy, but fun nonetheless.
    This week’s project(almost a year later) is moving it to a PCB. It’s funny how similar it looks to the picture above.
  3. @jamieriddles
    Nope, the microphone overlays an AC signal (voice, noise, claps, etc) on the DC ‘bias’ voltage used to power it.
    The AC is what we’re interested in :)
    @strider_mt2k
    not unless it’s very close, a very loud switch, or the threshold is too low…
Leave a Reply to strider_mt2k Cancel reply
