[George] just finished his first project: an 8×8 matrix “Board of Many Ping-Pong Balls” with 64 RGB LEDs. He started this project when he was 14 years old and finished the build over this last Christmas break. We won’t make any presumptions about [George]’s age, but we couldn’t think of a better project to start out on.
For the build, [George] used a Colorduino LED driver shield for his Arduino. This made the wiring simple, but the finished product is where this project really shines. For the base, [George] got a board laser cut at his school and used ping-pong balls to diffuse the LEDs. We’ve seen this many times but with this build there’s a neat way to drill a hole in a ping-pong ball; simply put the drill into reverse. The friction is enough to open the ball up, and the chips of plastic come outside instead of remaining in.
We’re really impressed with [George] and his winter break project. He’s lucky enough to have access to a laser cutter at school, and from a look at his monitor, he’s reading the right websites. You can check out his demo rainbow pattern after the break.
[youtube=http://www.youtube.com/watch?&v=m41S2sZquC4&w=470]
Nice project. The Colorduino is not a shield tho, its a full arduino clone. (like e.g. the Rainbowduino)
George is now 32.
Sounds like me.
They had colorduinos 18 years ago?
Ballsy!
no doubt this project took a lot of balls. I’d give it a shot, but I don’t have the balls to.
Nice build! For another way to put holes in golf or ping-pong balls, I made a fixture for both:
http://www.jcopro.net/2011/03/31/how-to-make-a-hole-in-the-middle-of-a-golf-ball/
Quite repeatable with a vise.
Ping pong balls are often made of nitrocellulose…very flammable. Here’s a video someone posted last time we had an article about an LED ping pong ball matrix: http://dl.dropbox.com/u/610802/fireshort.wmv
Whoah funky! Maybe a layer of spray resin would be a good idea :)
Whoa! – Was that you drilling ? It looks like the balls are set up in a similar matrix on a plate. What did you drill that ignited the balls on the plate ?
I actually don’t know who it was…they posted the video maybe a year back and I saved it :)
if drilling ping pong balls is such an issue, wouldnt it be easier to just heat up a piece of metal (like a nail if its the right size for your leds) and poke a hole in them?
Your ultra-low-speed drill concept is absurd.
Clearly what we need are faster drill bits, in an reduced-oxygen atmosphere.
Work clever, not smarter!
