[Matt Bell] sends a shout-out to Hackaday by creating a light-painting of our logo with his string plotter. He starts off by setting up a pair of stepper motors which each have a spool to wind and unwind a string. The plotter is made by suspending a stylus between these two strings. In this case, he’s using a wireless LED board (seen above) built from the remote control receiver/transmitter from a toy car. The link above is part of a Flickr set from which you can get the whole story by reading the captions of each image.
After the break we’ve embedded a clip of an in-progress light painting. You can see there’s some oscillation of the LED unit that makes it a bit less precise than the CNC light painter we saw a couple of weeks ago. It seems like string plotters usually don’t have this issue if the stylus has something to helpĀ stabilizeĀ it. We wonder if a piece of acrylic would help get rid of the shakes?[flickr video=http://www.flickr.com/photos/mrbell/6922555211/ w=470]
The sound of that thing is cooler than what it does.
Cool!
Needs run-up and slow-down to be ramped, this will reduce oscillations a little bit. I guess the impact on the light-print can be compensated by changing the intensity of the LED in proportion with the speed.
This is very similar to hackaday.com/2012/02/11/plotting-pictures-with-light/
I would think hanging the batteries a little lower might help in oscillations (or it could just make it worse), lowering the CoG
If you make a frame where the other ends are rooted along the sides and that back to the PCB you have slight or zero oscillations
How did you get the X,Y coordinates from the logo into the rig to control the LED position? Does the project have a detailed build page?
It doesn’t have a build page yet, but I think I will start one
Yes, please do create a build page. I’m interested in how you’re interpreting g-code with an Arduino. If you do write this up, please include some of the references you found helpful in creating this. Thanks for making something cool and sharing it with us all.
– Robot
The X,Y coordinates are sent to the plotter (an arduino connected to steppers) via gcode. The arduino then figures how long the strings needs to be and runs the steppers to get there.
We had a similar one a couple of weeks ago:
http://hackaday.com/2012/02/11/plotting-pictures-with-light/
This reminds me of hektor.ch and is of course, a totally awesome project.
