[Ch00f] finally made a breakthrough with his efforts dimming EL wire. He’s been at it for months and the last we heard his TRIAC idea had sputtered out. Not to be discouraged and with an determination we have to admire he has been hard at work reverse engineering others’ and developing his own methods. He put all of this knowledge to task helping a friend of his with a sleeping disorder, and made a dream-catcher that pulses at the approximate rate of an average person’s breathing (as determined by Apple for their pulsing power button lights).
Essentially the whole thing boils down to simply using a transistor to limit the current to the oscillator. A 555 timer is used to pass a triangle wave to the current limiting transistor at approximately the same rate as the Apple button (1/5 Hz). [Ch00f] notes that this isn’t the sinusoidal wave that apple uses, but it’s good enough. Finally a timeout power off is built in to the night light using a decade counter to monitor the number of triangles from the 555. This should keep the EL wire from wearing down faster, though we are hard pressed to think of a project we used EL on that has lasted anywhere near the 7 year service life of the wire.
Check out [Ch00f]’s page as he walks us through the process, or just watch his circuit in action after the jump!
[youtube=http://www.youtube.com/watch?v=jzcYCGBHbdc&w=470]
How about the annoying buzzing sound EL wire/panels make ? I can hear an EL backlight from metres away….
That’s dependent on the frequency of the AC used to drive the EL. Change the frequency, change the sound.
I know, i’ve used EL products before. The problem with EL is that it’s frequency dependant, it likes between 100 and 160 Hz, and the color actually changes a bit with frequency. Going over and under that frequency range results in no light or little light, so that’s not an option.
It really varies from transformer to transformer. Some of the cheaper ones have loose windings that “sing”.
next hack would be just to wind your own transformer.
Abite not very efficient, couldnt you make a servo controlled hand made variac?
Perfect timing for halloween. Glowing orange/red spiderwebs?
Another great write-up. And beautiful dreamcatcher!
Really beautiful. Nice work.
