A Brief History Of Unix Commands On Windows: CoreUtils (Again)
If you use Windows today and type ls, cat, grep, or awk in a terminal, there is a good chance something useful will happen. That was not always true. For most of the history of personal computing, Unix/Linux and Windows lived on opposite sides of a cultural border. Unix people had pipes, small composable tools, shell scripts, make, sed, awk, grep, tar, and the idea that everything was a file. Windows people had drive letters, backslashes, COMMAND.COM or cmd.exe, and an API that did not care much about what POSIX thought.
Yet there has always been a demand for Unix tools on Windows. Some of it came from programmers who wanted the same build scripts everywhere. Some came from administrators who missed grep and awk. Some came from companies trying to port big Unix applications to NT without rewriting them all. The result is a long, strange history of Unix-on-Windows layers, toolkits, compromises, and almost-but-not-quite compatibility.
Easy?
The simplest version of the problem sounds trivial. How hard can cat be? Open a file, copy bytes to standard output, done. Writing ls is a little more work, but Windows has directory APIs. Common commands like cp, mv, rm, mkdir are not very mysterious. Even pipes are not foreign to Windows. A lot of the everyday Unix command set can be ported as ordinary Win32 console programs with some path handling and enough patience.
But not all of Unix or Linux translates cleanly to Windows. The big issue is fork(). On Unix, a process can clone itself. The child gets a copy of the parent’s address space, open file descriptors, environment, signal state, and so on. Modern kernels make this efficient with copy-on-write memory, but the programming model is old and deeply baked into Unix. Shells use it constantly. Servers use it. Build systems use it. Scripting languages assume it exists, or at least that the surrounding environment behaves as though it does.
Windows process creation is different. Windows has CreateProcess(), which starts a new program. That is a perfectly reasonable model, but it is not fork() (more like fork()+exec()). If you are just launching notepad.exe, no problem. If you are trying to implement a POSIX shell that forks, redirects file descriptors, adjusts the environment, and then starts another program, the mismatch is extreme and you’ll have to do some strange things to fake things out.
One of the early commercial answers was the MKS Toolkit, originally from Mortice Kern Systems. MKS gave Windows users a pile of familiar commands, shells, and development tools. It was not just ls and friends; it included things like ksh, vi, grep, find, awk, make, and many of the utilities needed to move scripts and build procedures between Unix and Windows. The current PTC MKS documentation still describes it in exactly that spirit: Unix shells and hundreds of commands for interoperability with Windows.
MKS was attractive because it treated Windows as Windows. You were not necessarily pretending your machine was a Unix workstation. You were getting a Unix-flavored toolbox that could operate in a Windows environment. For many people, that was enough. You could write scripts, process text, drive builds, and avoid learning three different syntaxes for the same job.
AT&T Returns
A more ambitious attempt came from AT&T Bell Labs: UWIN, a pet project of David Korn of KornShell fame. UWIN stood for Unix for Windows, and that is more or less what it tried to be: a Unix interface layer on top of Windows NT and Windows 95, with libraries, headers, and commands. Korn’s 1997 USENIX paper describes the goal as building an open environment rich enough to serve as both a development and an execution environment, with nearly all of the X/Open Release 4 headers, interfaces, and commands.
UWIN is one of those projects that feels both obvious and heroic. Obvious, because if you have a bunch of Unix software, you want a compatibility layer. Heroic, because every POSIX semantic eventually has to land on some Windows behavior that was designed with different assumptions. File permissions, symbolic links, signals, terminals, process groups, device files, pathnames, and fork() all have edge cases. You can make the common case work and still spend years fighting the uncommon cases.
Cygwin
Then there is Cygwin, probably the most famous of the classic solutions. Cygwin became the go-to answer for people who wanted GNU tools and a fairly complete POSIX environment on Windows. The model is different from simply compiling ls.exe as a native Windows program. Cygwin provides a POSIX compatibility DLL. Programs built for Cygwin call into that layer, and the layer translates Unix expectations into Windows operations.
That is both Cygwin’s strength and its weakness. It is strong because a lot of Unix software can be rebuilt and made to run. The Cygwin project is explicit that it is not a way to run unmodified Linux binaries; you rebuild from source. It is also not a way to magically make ordinary Windows programs understand Unix signals and ptys. But for source-level portability, it has been remarkably useful.
The weak spot, again, is where Unix semantics do not map cleanly. Cygwin’s own documentation calls out fork() as “particularly interesting” because it does not map well onto Win32, making it difficult to implement correctly. Cygwin’s fork() is not copy-on-write in the usual Unix sense; it has to do substantial work to recreate the parent process state in a new Windows process.
There were other branches on the family tree, too. Microsoft had POSIX and Interix efforts, later wrapped into Services for UNIX. MinGW and MSYS gave developers lighter-weight GNU-ish environments aimed at building native Windows programs. Git for Windows brought a useful subset of MSYS2-derived tools to an audience that did not necessarily know or care what MSYS2 was. But the broad pattern remained: either you had native Windows tools that looked like Unix commands, or you had a compatibility layer that tried to preserve Unix behavior more deeply.
WSL
Then Microsoft changed the game with WSL, the Windows Subsystem for Linux. WSL said, in effect: instead of endlessly translating Unix expectations into Windows expectations, let’s run a Linux userland. The first version translated Linux system calls. WSL 2 went further and used a real Linux kernel inside a managed lightweight VM, which improved compatibility at the cost of making the boundary between Windows and Linux more explicit. Microsoft’s own documentation describes WSL as a way to run a GNU/Linux environment, including most command-line tools and applications, directly on Windows without a traditional VM or dual boot. The WSL 1 versus WSL 2 comparison notes that WSL 2 uses the actual Linux kernel in a managed VM for fuller system call compatibility.
This wasn’t a new idea. Things like coLinux and similar “kernels under Windows” had done this with varying degrees of success, but without the ability to fully integrate with Windows. Having it part of the “official” Windows landscape worked better, as you might expect.
The More Things Change…
But now the pendulum has swung again. Microsoft has introduced Coreutils for Windows, a Microsoft-maintained package based on the Rust uutils project. It provides native Windows builds of familiar Unix-style tools, packaged as a single multi-call binary, including coreutils, findutils, and a GNU-compatible grep. Microsoft describes the goal as making movement between Linux, macOS, WSL, containers, and Windows more frictionless, so the same commands, flags, and pipelines work more consistently.
That is not a replacement for WSL, and it is not trying to be Cygwin. It is closer in spirit to the old desire that made MKS attractive: sometimes you are in Windows, you are staying in Windows, and you still want tools that behave the way your fingers expect.
Of course, as we’ve seen, this is hardly a new idea. In fact, it is practically full circle back to the MKS toolkit. The only difference is the official support.
There is a lesson here. Running Unix commands on Windows is not one problem. There are at least three problems masquerading as one. First, there is the user-interface problem: people like the commands and want them available. That is easy enough. Second, there is the scripting problem: people want pipelines, quoting, globbing, exit statuses, and command options to behave consistently. That is harder. Third, there is the operating-system semantics problem: people want Unix programs to run as though Windows were Unix. That’s where there is the most friction.
So, yes, basic utilities are easy. But the Unix command line is not just a bag of executables. It is an ecosystem built around process inheritance, file descriptors, signals, terminals, pipes, path conventions, and fifty years of assumptions. Every attempt to bring Unix tools to Windows has chosen a different place to draw the line.
MKS drew it at commercial interoperability. UWIN tried to give Windows a serious Unix personality. Cygwin built a POSIX world in a DLL. WSL brought in Linux itself. Microsoft’s new Coreutils for Windows brings the everyday commands back into native Windows space. Sometimes things make a full circle.
But it all starts with a user thinking: Why can’t I list files on Windows with ls? We’ve used MKS, Cygwin, coLinux, UWIN, and even WSL. We’ve also thrown hardware at the problem.
17 thoughts on “A Brief History Of Unix Commands On Windows: CoreUtils (Again)”
  1. I’m curious how close the fidelity will be.
    I know that in powershell they ‘added’ curl; but just as an alias to invoke-webrequest; which only overlaps with curl’s behavior in a limited number of areas.
    1. curl on Windows is not a powershell alias to invoke-webrequest. it is an actual executable located in the Windows\system32 directory.
  2. I’ve no idea how faithfully arp was implemented in W11, but it’s a real boon and it still surprises me, how few are aware of it.
      1. Longtime HaD readers know that there is no one on staff with the skills necessary to improve the comments page, and they don’t have the British concept of “get a man in”, no offense ladies and laddies.
          1. It’s just the standard WordPress comment plugin, right? Jetpack or something like that? Maybe they’re open to modifying it locally, but with every update the changes get reverted? That’s my experience with PHP/SQL web portals. Don’t bother customizing them because updates just break your site all the time. They really should just move away from WordPress. What a bag full of monkeys.
  3. I tried Microsoft’s new CoreUtils on my Windows 11 laptop just a few days ago.
    The “tail” command can show you the last lines of a file, but “tail -f” used on a log file doesn’t follow it. Nothing beyond those lines prints as the file grows.
    Coreutils has “more” to view text files, but not “less” which lets you scroll back up and do simple text search.
    The “ls” command defaults to non-color display. But “grep” uses color by default, so it’s not like color text is impossible for Microsoft. Black and white “ls” really feels like ancient unix.
    The install process using command line “winget install Microsoft.Coreutils” munged my PATH, failing to add a ‘;’ separator so its directory with these commands and other previously in my PATH no longer worked. Easy to fix, but not a quality experience.
    Attempts to remove it with “winget uninstall Microsoft.Coreutils” printed some stuff about uninstalling, but stalled indefinitely. I let it keep trying for a few hours, just out of curiosity, before just manually deleting the files and editing my PATH.
    Maybe future versions will improve, but my experience with Microsoft Coreutils was pretty dismal.
    1. Yep. Mr Stoffregen speaks the utter truth. Had similar problems; and more. M$, in the general sense, will always suck. I’ve never been dissapointed by Mickeysoft because I’ve never expected much from them.
      About 20 years ago, I re-built some of my crap using cygwin. Minimal problems. Why did I re-build stuff for windoze? Because the wife wanted to use her computer to talk to my H/C systems. Geez, the stupid things we do for love.
    2. Powershell aliases some commands in not-so-helpful way. For example its “wget” just downloads but doesn’t save the file by default!
  4. I’ve been using Busybox for Win32 for years, and it easily trots rings around coreutils when it comes to functionality. It also helps that it is tiny (a single binary of about 640k), well supported, mature code, performs decently and has a fairly competent [b]ash shell implementation.
  5. Windows not having Unix like tools was solved a long time ago, Cygwin was how I built and packaged K-3D for Windows users, decades ago.
  6. The problem with Windows starts with the shell. As with many Windows things, there is a shallow adoption of others standards. The Unix tools work well when paired with the shell. When you want to grep based on a file pattern the shell adds all the files. Windows shell, at least cmd.exe does not do that. So even if you get a copy of grep to run, your experience will not be the same.
    You need a Unix shell and the tools.
    1. Strip the object abstract off the top, and one is left with everything else people usually have to deal with.
  7. The power of the Unix shell comes from the ability of the commands to do a whole lot more than the obvious. The command ‘cat’, for example, doesn’t list a file. It concatenates files and directs them to stdout by default. If you just give it a single, complete, filename and nothing else it will write the file to the terminal. Its this ability to stack operations and pipe results that gives the command line so much power (especially when you put the commands into a text file — a shell script — that saves you from the inevitable typos).
    Cygwin has always done an amazing job of persuading Windows that it can be Unix. It will struggle with commands like ‘fork’ because its trying to hit a moving target. (There was a time, way back in history in the time of Win2000, when the Windows kernel was POSIX compliant. That didn’t last, of course.) But if you understand the environment and accept the limitations then the result is extremely useful. Obviously if you want the real thing there’s no particular reason — outside of ‘corporate’ — not to go for it. Windows makes a good terminal but a lousy computer.
