By now you might have a bit weary of your small and inexpensive TV tuner dongle software defined radio. Yes, using a USB TV dongle is a great introduction to SDR, but it has limited bandwidth, limited frequency range, and can’t transmit. Enter the bladeRF, the SDR that makes up for all the shortcomings of a USB dongle, and also serves as a great wireless development platform.
The bladeRF is able to receive and transmit on any frequency between 300 MHz and 3.8 GHz. This, along with a powerful FPGA, ARM CPU, and very good ADCs and DACs makes it possible to build your own software defined WiFi adapter, Bluetooth module, ZigBee radio, GPSÂ receiver, or GSM and 4G LTE modem.
It’s an impressive bit of kit, but it doesn’t exactly come cheap; the bladeRF is available on the Kickstarter for $400. The folks behind the bladeRF seem to be doing things right, though, and are using their Kickstarter windfall for all the right things like a USB vendor ID.
There’s a video of two bladeRFs being used as a full duplex modem. You can check that out after the break.
300 Mhz Lower band limit? It’s missing much of the amateur bands!
Wow, definitely a strong competitor to the USRP.
The hardware based on it’s frequency range is probably based on the http://www.limemicro.com/lms6002d.php I’ve been working with one of these + a raspi and a DE0nano FPGA board for a while with GNURadio. For the money, it solves a ton of the RF engineering that would usually complicate such a wideband SDR. Adding the lower frequency would couple all of these problems back into the design.
Yes I looked at the schematic they have up it is just uC + FPGA + LMS6002Dr2
http://www.limemicro.com/download/LMS6002Dr2-DataSheet_r2.pdf
I saw another start up working with SDR and it covers much lower frequency ranges, but a little bit more expensive.
http://www.pervices.com/support.html
300 MHz lower bound in a $400 radio is quite a bummer, lots of interesting things are happening below that…
I agree. I’m just now getting into ham radio as a participant and most of the really good stuff in my area seems to be happening on 2 meter.
Most interesting stuff is below 30 MHz.
Care to put some examples? (Sorry im dumb!)
All the ham bands below ~8m (10, 12, 15, 17, 20, 30, 40, 60, 80, 160, 600 and 2200 meter) as well as 500kHz experimental, submarine communication, short-wave, cb, low frequency FM, and weather. Also, you’re not dumb, just uninformed, and your willing to change that, so +1 to you!
below 30 MHz is the Grandpa Spectrum.
(it’s pretty dull)
At 400$ you’d think they could afford just afford a 300 MHz DAC and cover that part of the spectrum without mixing.
Looks like Nuand has already addressed the 300MHz issue (they left a comment that addressed this on their kickstarter page):
“The usable frequency range of the bladeRF does indeed start at 300MHz but goes up to 3.8GHz. Having one (or even two) front-ends spanning this many octaves is a challenge, however the bladeRF performs exceptionally well over the entire range. That however may not have been the case had we included the circuitry needed to reach those lower frequencies. As a solution, we added an expansion board interface to the bladeRF which allows for expansion boards that can drastically expand the bladeRF’s reach into HF, VHF, SHF, and EHF.”
Yes it has a 300MHz lower limit – but the advantage is being able to cover things such as WiFi, bluetooth HDTV reception etc…
FYI to receive things below 300MHz you can use a hetrodyne up-converter to mix the frequency of interest up to 300+MHz. Ham operators do this often for microwave stuff.
Here is a blurb from wikipedia:
http://en.wikipedia.org/wiki/Heterodyne#Up_and_down_converters
You can check out http://www.pervices.com/support.html…a little more expensive but goes down to 100kHz
My mistake:
http://www.pervices.com/support/
This certainly could complete with the Ettus Research equipment, now owned by National. Semi.
The educational documentation part of this Kickstarter is very good idea.
So there really isn’t anything at this price RX/TX that covers up to 3GHz with the documentation and is open source. Well done guys.
*National Instruments ;)
My SDR just came in the mail yesterday, not tired of it yet. $15, cheap enough to break.
Can it do .1 increments in the bands?
Also, whats below the 300mhz band?
Also, what’s the use for these? Other than maybe encrypted wireless data transfer between two secure points.
Most ham radio operators talk on the bands under 300Mhz
Then they get the daughter board.
Weather satellite & HAM VHF – 144 MHz
Airport VHF Comms – 110 – 140 MHz
Commercial FM Radio – 88 – 108 MHz
HF CB – 30 MHz
Lower frequencies are becoming LESS cluttered now, the many of the old Shortwave stations are moving into Internet broadcasting. Tough luck for the impoverished third world people relying on HF to keep in touch with the world, hey?
Use a cheap ($20) device to cover all these frequencies, you don’t need a $400 device for that.
You are forgetting this is a transmitter and receiver not just a receiver and it has much better filters.
Now this is what i like to see, pro gear with a hacker mentality and at $400 i don’t know how they can even turn a profit. I’m old enough to remember sending images over phone lines and ham radios so seeing hardware like this leaves a taste nostalgia.
@Matthew
In theory you could use this platform to prototype devices that operate on any band within the 300MHz to 3GHz Bandwidth. IAll you need to do is implement the modulation scheme on an FPGA. And, since FPGAs can be modified very quickly with a software change, we can have a multi-bandwidth radio.
In other words, it can be a cell phone one minute, an amateur radio the next, or a Low Power TV Transmitter afterwords because we can change the software on the FPGA to do whatever we need it to do.
@All
Check out the bands here.
http://reboot.fcc.gov/spectrumdashboard/searchSpectrum.seam
I’d like to see a demo of this in conjunction with openBTS.
Bingo. Why can’t we get CHEAP OpenBTS gear? The closest we have is either buying the full USRP/USRP2 or shelling out $1800+ for the “dedicated” UMTRX product.
Why not run it on a $10 front end?
http://www.youtube.com/watch?feature=player_embedded&v=B1od4x9L3t4
Excellent, this was great, I used to work for TI and I know Calyso very well, I may buy one of those phones and start playing with it.
This is rather amazing. I used to work as a factory tech on some communications monitors that covered 10 KHz to 1 GHz, and it ran about $12K. It did have a 10 MHz crystal timebase, O’scope, Spec Analyzer, function gen, and power meter. It had additional options for analog cell phone testing and beeper testing. Did I mention that this was quite a while back?
You are compating a Lamborghini with a Fiat Punto here. They are not the same.
There is the ability to add expansion boards so HAM radio will be covered!
What a bargain — blows Ettus Research devices out of the water in terms of price/performance. I’ll have to add a PA after this product though…
Yes the 300 MHz Lower band limit, is bit of a bummer, but equipment as this could be a positive for amateur radio. While I haven’t done the math, I belief it’s safe to say Amateur radio has more bandwidth allocated for exclusive/primary use above 300, than it has below 300. Bandwidth we are likely to loose if we don’t start using it. As for there not being anything interesting below 300MHz, hell there is interesting things happening below 30 MHz, interesting being relative. I don’t have a clue, if this can be made operational with a USB 2, but USB 3 is likely to lock out many computers from the play ground. Do hope they meet their goal, but I don’t know when I’d be able to purchase the product.
n0lkk: They claim the board is supported by the Rasberry Pi, which is not USB 3.0 capable. I would assume it can operate using USB 2.0 albeit perhaps with a lower sampling rate, or bandwidth.
USB 3 is the very right direction because it would open up more bandwidth than Gigabit Ethernet (Ettus is stupid to not offer this feature).
As you can see on their (other) picture, they have connected it with Raspberry Pi that does not have USB3 interface meaning that the USB3 is not mandatory.
In addition if you have a PC then you can buy an USB3 extension board to open up all the bandwidth.
its for wank factor. There is probably a full blown linux running on that FPGA (nios) at speed comparable to rasspi.
You can not run Nios on that FPGA, it does not heave enough reousrces. The FPGA is only used for data interface between the LimeMicro LMS6002D and the Cypress USB 3.0.
Well it depends on how many resources are left. I’d say if they can run it on the default 15kLE FPGA, the 115kLE one will have plenty of room for the ~2500LE (700LE minimum) NIOS.
It would be nice if we could attach come fast ADC to GPU via PCI-Express bridge. I saw gtx460 decoding simultaneously 150 5MHz channels.
Can you post a link?
Article: “A Real-Time Capable Software-Defined Receiver Using GPU
for Adaptive Anti-Jam GPS Sensors”, from here: http://waas.stanford.edu/pubs/index.htm
Excellent article, thanks a lot, really educational.
What a great use for a GPU. You could run an over-the-air PBX.
one of those things i can think of a ton of uses for and could picture deving on but simply cant afford it >:
Hey guys, I’m John (the guy from the video). We are very excited to have made it here on Hackaday! We just wanted to post up a comment that we also left on the Kickstarter page addressing the concerns of those interested in frequencies under 300mhz. The usable frequency range of the bladeRF does indeed start at 300MHz but goes up to 3.8GHz. Having one (or even two) front-ends spanning this many octaves is a challenge, however the bladeRF performs exceptionally well over the entire range. That however may not have been the case had we included the circuitry needed to reach those lower frequencies. As a solution, we added an expansion board interface to the bladeRF. One of our first expansion boards will be a block up/down converter. We wanted to wait a little bit to get some feedback from people to see what frequency ranges people were interested in seeing. As of now it seems very likely that we will look at going from as close to DC as possible up to a minimum of 11GHz. So as soon as we do our engineering homework and see what’s possible we will make an official announcement about this on the Kickstarter page.
To transmit fast RF, I would recommend the MAX5879 from Maxim. Kick ass part, beats ADI in performance and cost. Gotta’ like that.
you can’t even see a datasheet without registering and requesting it, it say custom order and restrictions apply. I’m sure that will be real hacker friendly and easy to buy ….
Closed-source PCB layout.
Looks closed source – and at $400 over priced. Fail.
They are trying to sell a good product. I do not know why they should give it away for free.
Beside of that, it is an unique product that does not exist currently in the market.
1 Because its on kickstarter and they are taking donations.
2 There is plenty of products like that, just at different price points.
They are taking donations to start closed source product – clearly most hackers are against this.
They’re keeping the board design itself closed, but the software, HDL, and schematics are open.
Then they are 75% of the way to making me consider funding them! Good job guys, only 25% to go!
Here is my take on closed PCB design.
Firstly, they used BGAs. That SEVERELY limits the ability of anyone without professional equipment to assemble let alone modify the board. You almost have to go to that kind of packages these days if you want the leading edge stuff. Plus it saves a ton of board space. I totally support this.
The schematics are all you need to understand the design. Unless you are an RF PCB designer, having the gerbers won’t do you any good anyway since you won’t be able to understand them. That’s a true art right there. I would say there is no way they used Eagle or KiCad here either so unless you feel like spending 5K+USD on a cad package, you can’t look at the design files anyway.
So seriously, closed PCB doesn’t detract from this at all as far as I’m concerned. I bet all you people who are complaining about the closed PCB would never even look at the layout even if they were available. It’s just something to complain about. That’s the case for most hardware products. Realistically, how many of you would even be able to produce something as simple as an Arduino on your own from scratch given only the design files? I’m guessing most of the people who go crazy over the newest cardboard case for the raspberry pi have no idea about this kind of stuff, which is fine.
I’m actually super excited about this board and plan on getting one when they start selling them through something other than kickstarter. Good job guys.
What about HackRF? I haven’t seen any activity since last November.
https://github.com/mossmann/hackrf/
Here http://ossmann.blogspot.com/search/label/hackrf is the blog you can find the updates.
Tks Kris Lee for the HackRF blog link. I was stuck on the Github page…
The RF front end alone is a $50 IC. The FPGA isn’t cheap, and they’re selling it on a nice little pcb (with proper rf design I assume) with rf performance validation. This is a steal at $400.
Actually, looks like the RF chip is USD $110, unless I’m mistaken. http://www.limemicro.com/buy_now.php
The RF front end alone is a $50 IC. The FPGA isn’t cheap, and they’re selling it on a nice little pcb (with proper rf design I assume) with rf performance validation. This is a steal at $400. You could argue they should have designed it differently and somehow made it cheaper but the closest thing on the market is the Per Vices Noctar and it’s twice as expensive.
This is an interesting project, but they sound a bit scamy to me. 28MHz bandwidth with a 40MS/s ADC is just too much to believe and the image they have powering this board using a RasPi is just a BS marketing ploy.
The FPGA they are using is really not made for any kind of signal processing, it can only be used for really simple buffering, the price of the FPGA they use is $25, so it is not as expensive and people think they are. This FPGA is even smaller than the one used on USRP1, so they will mainly use it for data trancfer only.
And for the ARM9 processor on board, it is another half truth, they ARM9 is inside the USB3 device, it will be 100% loadded with USB3 transfer and will not have time to do anything else if one wants to use the full capacity of USB3 5Gb/s speed.
It is amazing that people who know electronics don’t react to this kind of half truths.
The total BOM of this device is less than a $100, selling it on KickStarter is an excellent way of getting free publicity.
@kk5711, you hit this nail on the head. My thoughts also before spewing my $400 = Fail comment. The only thing I can see as possible contributors to the high price are (1) multi-layer PCB with special substrates? (2) large license or NRE fees associated with the RF transceiver part? (3) Intellectual property (IP) licensing costs for FPGA cores, or something to do with the USB3.0 interface software? But I doubt it.At $200 bucks, I “might bite” if it was truly open-source. At $400 and non-open, nah.
I also would question the phase noise performance of the on-board L.O.’s in that RF transceiver part. They may be suitable for sniffing around the microwave bands, but add the noise of an upconverter stage and the typical narrow band weak signals you work with at VHF/HF and you might end up with a relatively poor performer (not to mention difficulty in tuning over small steps like 10Hz). A better approach is to divide the L.O. frequencies to lower phase noise in the first place, but this may not be possible with the part they’re chosen..
Want one, but probably never will :/
Might be an easy way to construct a microwave propagation beacon…
I know some things at 330 and 440 Mhz I can use this for that still stands undefeated after 3 decades…
HF bands (<30MHz) is still very popular. I just capture small part of radio spectrum ~90kHz @3.5MHz.
http://www.dodaj.rs/f/10/p0/2K6ScFAU/3500khz.png
You will see more active station than comments in this post, and all of them using the simplest possible CW communication and at the right side of waterfall spectrum, modern BPSK digital modes. This is captured with my hand-build ZMSDR (0.1 – 30MHz) SDR receiver.
Today i find this :http://www.comblock.com/com3011.html
20-3000MHz receiver with fpga.
nice pice of kit but as much use as a chocolate fire guard, Most of the interesting stuff is transmited below 450Mhz
