Sonic Screwdriver Meets TV-B-Gone
sonic
[furrysalamander] has a friend that is a really big Doctor Who fan. It happens that this friend has a birthday coming up, and [furrysalamander] wanted to get her something amazing. A Sonic Screwdriver is always a great gift, but [furrysalamander] wanted to put his personal touch on it. He ended up adding a TV-B-Gone to [10]’s screwdriver, turning a fictional deus ex machina into a functional device.
The body of the Sonic comes from this replica of [10]’s screwdriver from Think Geek. Inside, the screwdriver has space for a battery a circuit board to control the lights and sound normally expected of a sonic screwdriver. [furrysalamander] added a freeform circuit composed of an ATtiny85, a transistor, LED, and a few resistors to add the ability to turn just about any TV off.
Of course [furrysalamander] needed to program the ATtiny with the TV-B-Gone firmware, and lacking any AVR development tools he used a Raspberry Pi’s GPIO pins to write the firmware to the microcontroller. That’s something we’ve seen before, but [furrysalamander] is a champ for including the process in his Instructable.
The end result is a Sonic Screwdriver that doesn’t work on wood and can’t break a deadlock seal. It turns off TVs just fine, though, and looks great to boot. You can check out a demo of [furrysalamander]’s sonic in action after the break.
35 thoughts on “Sonic Screwdriver Meets TV-B-Gone
    1. I’ve actually considered it a lot over the past few days, but my only concern is how hard it was to fit everything inside. I suppose you could forgo the external oscillator, but I’m not sure how that would effect how well it works. That, and there’s the initial cost of making the kits to sell. Maybe this summer I could do something like this instead of my crappy job I had last year.
      1. You could definitely forgo the oscillator. If you want to test this, try reprogramming your existing device with the fuses that cause it to use the internal 8MHz oscillator; I think you’ll find that it works just fine.
        Another option for shrinking it down is to move to SMT parts. With a decent soldering iron and a cheap pair of nonmagnetic tweezers, it’s at least as easy to do large pitch (like SOIC, 0806 etc) surface mount parts as it is to do thru-hole.
        1. Excellent point. If I do end up redoing mine, I believe I will leave out the oscillator. However, last time I tried doing SMT soldering, my hands shook too much, but then again, it was one of the smallest parts I’d ever seen on something, so I suppose I could try again.
  1. Theoretically maybe this could fly a IR helicopter that would be so freaking cool. or possible just crash someone else’s ;)
    As for setting it to random patterns it would make quite the impression when pointed at a home theater system and would freak out people so much I NEED ONE NOW!!!!!!!!!!!
    1. I think a IR helicopter can not controll by it
      a heli use 2 sticks 1 for direction 1 for the rotorspeed
      u must use a giro to replace the stick for controll but how you controll your speed
      all the time full power not work i think
      1. That’s what I was thinking. You’d have to convert it to gyro, but I’ve seen gyro controlled helicopters before, so you’d just have to have an extra button or two.
      1. Why not? This is a delightful thing. Please note that even if the KS doesn’t raise the money, it *is* telling you how much demand there is for your product. Free market research!
  2. This is a fantastic hack furrysalamander! Though I must confess, when I first saw this I did a certain amount of shaking my fist at the sky. I’ve been working on a SonicPen (like from the Adipose Ep) for a friend of mine as a birthday present and the core of it is a TV-B-Gone. I’m tweaking my design though after reading your instructable, thanks for a good read and confirming that not only can it be done but that the results are great too!
    1. Yes, it’s definitely difficult, and you CAN leave out the oscillator if you burn the fuses to not use one, but it’s worth it. My friend thinks I’m amazing now.
  3. And in school… “The TV’s on the fritz, so – I guess we’ll have a pop quiz…”(long moans).
    But WAIT! There’s MORE!!! For just 9.95 you can get a mate to turn ON TV’s!!! (Just pay for separate Shipping & Handling.)
    Unsure you should crowd source. It raises awareness. You get caught. Stealth is shot to heck. Yup, want one!
Leave a Reply to furrysalamander Cancel reply
