3D Printed, Solderless Circuits
3d printed board
If you’re looking for yet another alternative to etching your own PCBs, then check out this new Instructable on 3D printing test circuits!
[Mikey] decided to try out this method when he needed a small board prototype. He designed the perfboard to have a standard thickness—only 1/16th thick (~1.6mm)—with thin, recessed channels on one side and through holes on the other. [Mikey’s] circuit board allows you to stuff your components in, hold them down with a piece of tape, and then fill the channels with some kind of conductive material. In this example he’s used a highly conductive paint.
This 3D printed option probably won’t suit all your circuit-building needs, but it could provide an excellent shortcut for your next hack! As always, there’s a video after the break.
Unlike printing your PCBs on a regular inkjet printer, buying a Kickstarter robot PCB printer, etching your own, or modifying your 3D printer to extrude solder, this hack is probably the easiest method you can use—assuming you have the skills to make the 3D model and have access to a 3D printer…
[Thanks Barry!]
47 thoughts on “3D Printed, Solderless Circuits
  1. With a little bit of effort this could be easily used to print out new PCBs for more 3D printers. Just use Gallium or Fields Metal for the traces instead. You can then print a layer on top of that to protect it. This could potentially lead to cheaper PCB manufacturing in small batches. Say a poor man’s 3D printer?
          1. Bearing in mind the old melting-teaspoon trick (those Victorians and their wacky heavy-metal antics!), I’d guess it’s below tea temperature but above hand temperature. Unless you kept the spoons chilled beforehand, or something.
            To me, the only way I’d think it was a good idea to trick people into drinking Gallium would be after the severe brain damage caused by drinking Gallium.
            I suppose if it’s poisonous, you could always swallow a load of Arsenic to neutralise it into LEDs.
  2. I don’t see any reason to do this apart from pure novelty, or maybe to include a couple of traces to an LED on the inside of some 3D printed toy.
    The main problem is how fragile and unreliable conductive paint is, and how high the resistance is.
    Basically i’m saying that it will make a really cute conversation piece but it’s not a viable way to make circuit boards, just order the damn things from china or etch them using traditional methods.
    1. small steps towards three dimensional circuits. Imagine adding a third dimension to your pcb designs. integrating them with a functional structure. it may seem silly now, but this WILL be a game changer at some point. think big bro.
          1. I suppose the problem is, partly, that circuit diagrams have always been 2D, designers are used to seeing electricity move in 2D. Perhaps an increase in Verilog and the like could help computers make the jump. I wonder if you could invent an analogue version of Verilog / VHDL? Would be interesting to see a description of something like an AM radio to start with.
    2. I have two comments to this:
      1) It is a beginning, maybe we can develop better techniques, better conductive inks, or other complementary technologies
      2) It may be exactly what I need. Like a lot of people here I have the need to make small numbers of prototypes, one offs, etc.
      Only problem is I have a early onset arthritis (it is more complicated than that, but lets not worry about the details), and my hands shake. I can control them long enough to solder (provided I take a breaks), but it is painful to do for extended periods. Add in measuring and cutting lengths of wire for protoboards and it can be excruciating.
      Because of my disability, I don’t trust myself around caustic chemicals and the precision needed to make PCBs at home. Nor do I have a spare $500-$1500 to drop on a PCB mill at the moment.
      But I do have a 3D printer. If this technique proves useful then I can make prototypes and proofs of concept and then, and only then send off for PCBs; hopefully saving me time and money.
      For the same reason I am very curious about the silver nano particle inkjet technique described the other day (http://hackaday.com/2013/12/05/instant-inkjet-circuits-with-silver-nanoparticle-ink/)
      1. Depending on how far back in time you want to go, the first steam engine was used to open large temple doors automatically when a ceremonial fire was lit.
        Usually when an invention is worth something, it is put to some sort of productive use almost immediately. Conductive inks as PCB traces have been around for decades and they’ve remained a novelty because they’re not really suitable even for prototyping circuits.
        After all, we can simulate the circuit before committing it to a board, so it’s really only useful for people who don’t want to learn the tools of the trade.
        1. I disagree with your core premise, but I am no interest in debating that point.
          Conductive inks are far from a novelty, as [tekkieneet] pointed out they are silk screened for button contacts. I have seen other uses as well.
          Breadboards aren’t super portable, or convenient for putting in enclosures. The point of this is that is combines something new (an easy way to make boards) with something established to provide a new possibility. It wasn’t really practical to do this until the advent of cheap 3D printers.
          Now let me head off another complaint: durability. Most (but not all) one off PCBs have the useful life of unrefrigerated eggs. This is faster and cheaper than sending off for small runs of boards, and less time consuming/risky/caustic/toxic than etching boards at home.
          And of course, there are other materials coming on line that may be much more useful than traditional conductive inks. Like the silver nano-particles mentioned in an earlier HaD post
          1. I have an old keyboard here that has more or less all of it’s resistors printed onto the pcb in what looks like some form of carbon. No markings, completely matt black blobs, some thick some thin. I have never seen these before or since but the manufacturer obviously thought it to be more cost effective to print them rather than then penny or 2 it would have cost to place real ones.
            Not really making a point I just thougtht it was interesting and kinda relevant. I wonder how many other types of component can be made in this way? Perhaps a capacitor buy placing a dielectric between 2 layers of printed resistor??
        2. >consuming/risky/caustic/toxic than etching boards at home.
          FYI: A few common use for those “toxic” chemicals you are so afraid of.
          IHS Chemical: In Western Europe, ferric chloride is used mostly as a coagulant for sewage treatment and potable water production.
          Wiki: Ammonium persulfate is a standard ingredient in western blot gels and hair bleach.
          So if your “proto” isn’t durable, you are going to THROW it away at some
          point and opt to make a proper PCB anyway, right? So that’s same amount
          of etching chemicals PLUS more waste from the “proto”.
          The only “toxic” part is the copper compound in the waste to lower lifeforms.
          You can easily neutralize it and make it insoluble and harmless.
          If something is worth building, it is worth building well. I spend my
          time designing thing to work correctly, so pretty much the initial
          “proto” IS the final product. Most of my PCB (“proto” and one-offs) are
          build to last and serves useful purposes.
          I have a UPS on a home made PCB that is running 24/7 for 3+ years so
          far. I trust it enough to for my VoIP/internet.
          1. I think you are focusing only on one aspect of what I said. Please refer to my description of my arthritis and my hands.
            But more to the point, I used to make boards at home, and I know the chemicals involved. So when I say I don’t want to touch them with my condition, I know what I am saying
          2. Even easier recipe: hydrogen peroxide + citric acid + table salt. Everything is safe (I checked 3% solution of hydrogen peroxide works, and it does not burn skin), resulting chemicals – are neutral, more or less (copper citrate? It is not caustic and does not cause stains).
          3. @fhunter Good to know, but if you were addressing me (which I admit isn’t clear) you, like @tekkieneet seem to be missing the other things I said about why making PCBs at home isn’t suitable for me (or people with similar issues). The nature of the materials used was just one factor.
      2. Carbon conductive ink silk screened on top of contacts are often used in
        a cheap IR remote control. Sometimes it is also silk screened on top of
        solder mask as a substitute for wire jumpers for the single side PCB. It
        is only used for circuits where the high resistance is tolerated.
        I have seen metal conductive ink used in a few applications. e.g silk
        screened onto mylar sheets in keyboards, applied in plastic case as last
        ditch EMC fix.
        To have any practical use for modern day digital parts that requires
        power decoupling, you have to get the resistance down. To get the ink
        conductive enough, you pretty much have to silk screened as a thick
        layer. The viscosity is going to be the limiting factor for any fine
        geometry “printing” you are going to do.
    1. Maybe adding a ring a bit like the collective pitch on a helicopter’s rotor but upside down. With a “finger” to press down and direct the, say enamelled copper wire, into place as the rest of the project is printed. Maybe a follower head to tack it down as it goes.
    2. If there is a future in 3D printing PCBs, perhaps the laser-sintering method will do better, since it can produce solid metal very easily. Of course dealing with 2 different materials, 1 insulator, 1 metal, would be hard. Perhaps you could lay a layer of metal powder, sinter it, blow the dust away, then do the same with plastic powder.
      Though in sintering printers the powder is left behind layer by layer to support the print. Difficult… Maybe use a liquid to support the powders on a level. Possibly with some sort of surfactants in there.
      1. Wiki on solder:
        The following are some of the solder types. It would give you some idea
        of temperature range. Sn = Tin, Pb = lead, Ag = Silver, Cu = Copper
        Numbers are percentages.
        lead Sn62Pb38 183C
        lead free Sn95.5Ag4Cu0.5 217C
        lead free Sn96.5Ag3.5 221C
        There is no reason why you have to deposit molten solder other than
        convenience. Solder paste is easily available on ebay. A bake in an
        temperature controlled oven is all you need to “reflow” solder and even
        solder things!
        I got a different idea. Copper wires comes in a spool and much better
        conductor than any ink. May a specially mass produced perf board that
        are divided into component area and bus out the pads into routing areas.
        The “machine” X/Y route copper wires and terminates them onto pads in
        the routing area. It covers pad with solder paste when done. After it
        cooled off, you can populate the board the usual way.
    1. https://en.wikipedia.org/wiki/Carbon_nanotubes#Toxicity
      “Carbon nano tubes deposit in the alveolar ducts by aligning length wise with the airways; the nano tubes will often combine with metals. [73] The needle-like fiber shape of CNTs is similar to asbestos fibers. This raises the idea that widespread use of carbon nanotubes may lead to pleural mesothelioma, a cancer of the lining of the lungs or peritoneal mesothelioma, a cancer of the lining of the abdomen (both caused by exposure to asbestos). A recently published pilot study supports this prediction.[74] Scientists exposed the mesothelial lining of the body cavity of mice to long multiwalled carbon nanotubes and observed asbestos-like, length-dependent, pathogenic behavior that included inflammation and formation of lesions known as granulomas. Authors of the study conclude:
      This is of considerable importance, because research and business communities continue to invest heavily in carbon nanotubes for a wide range of products under the assumption that they are no more hazardous than graphite. Our results suggest the need for further research and great caution before introducing such products into the market if long-term harm is to be avoided.[74]
      Although further research is required, the available data suggests that under certain conditions, especially those involving chronic exposure, carbon nanotubes can pose a serious risk to human health.[69][70][72][74]”
      1. So are you trying to say that might not work?
        or are you just pointing what is true of the vast majority of materials used in manufacturing (including sawdust)?
        Your comment did make me notice something i hadn’t before, however.
        That is, the section you quoted above was about the only negatives present within that rather large wiki page regarding the properties and potential uses of carbon nano structures.
        thasnks,
        ursus
  3. Also possible are alloys using indium and other metals.
    One that has been studied is as little as 8% indium but as it just fills up grain boundaries you don’t need as much of it.
    Also useful are bismuth/indium/tin/zinc alloys as no lead is present, yet the MP is still less than 120C.
  4. How about taking a piece of board, putting on a swath of double-sided sticky tape, then placing bare wires and components on it, then dab all the junctions with solder. Presto, quick circuitmaking without a 3000+ bucks 3D printer and 50 bucks per microliter conductive paint.. And it’ll still be feeble, although a swipe with some epoxy should fix that.
    1. Lovely strawman you have there, pleased to meet it ;)
      I suggest you revisit the prices of 3D printers, they have really come down in price. But you are right if your point is that it would be foolish to buy a 3D printer just to make circuit boards. However if you already own one, well that changes the math.
      And yes conductive ink is expensive, but an ounce goes a long way. I use a bare conductive pen for the occasional prototype and interactive cards and I am just now running out.
      I have a hard time grasping the negativity to this post. It is just one more tool out there. Maybe it will be nothing more than a novelty and of limited use, or perhaps it is the beginning of something bigger. No matter what it is a cool hack, and every hack we are exposed to helps inspire something else.
Leave a Reply to tekkieneetCancel reply
