Manual Pick And Place
picknplacePopulating a large surface mount PCB can take forever. [craftycoder] from Freeside Atlanta has built a great looking manual pick and place machine, removing the need for tweezers. No more will passives stick to your tweezers while you are trying to place them on your PCB!
We have seen a lot of pick and place machines in the past few years. What makes this one stand out is its simplicity and the no-nonsense build. This pick and place is built on an MDF platform, uses bearings from Amazon, standard 12 mm rails, and has a small camera for a close-up look at your part placement. Sure it is a manual method, but it beats painstakingly placing each part with tweezers. It would be interesting to see how much this entire build cost; we expect that it was not too expensive. See this thing in action in the video after the break.
We hope this project has inspired you to go out and make something cool! If so, let us know what you have made!
https://www.youtube.com/watch?v=6ImOgzUy6QU
13 thoughts on “Manual Pick And Place
    1. Good idea, AKA the A. One way to implement this would be to use a stepper motor as a switchable dashpot. Just use a momentary pushbutton to short-circuit the windings.
  1. Cool build! That looks very useful, despite the lack of CNC (which is always an option down the road). Just need to adjust that camera so the part is actually visible. In fact, it’d probably be a good idea to attach both the camera and the vacuum head to the Z axis, so they move together.
  2. I agree, cool build. I think the next step could be to make it semi-manual. Use encoders to keep track of the X-Y position, and map out areas where the different component tapes are. It sees that you picked up a resistor from a certain area, and then gives you direction LED’s to direct you to the right set of pads. This would give you an increase in speed by not requiring you to verify where each part goes, but without the accuracy needed of a true pick-N-place machine.
    1. +1, except his current system seems to need the board itself to move and rotate quite a bit, so solving that problem will have to come first (like allowing the vacuum tweezer to rotate, with optional 90 degree detents).
      1. Didn’t read the article, so I may have missed some details. From what I saw in the video the tweezers did rotate, but he didn’t have the board secured, and just moved it as needed. So yeah, that would have to be considered.
        Kinda reminded me of the differences between a GoTo telescope, a scope with digital setting circles, and a truly manual one.
Leave a Reply to ferdnaCancel reply
