Pain is a good thing. It tell us to pull our hand away from the stove and to stay off a turned ankle. But we all have different experiences of pain, and chronic pain degrades our quality of life. A person’s reports of pain will vary from one day to the next based on many factors, so the 1-10 scale isn’t universally effective in determining a person’s pain level. [Scott]’s entry into The Hackaday Prize is based on the classic cold pressor testing device, which measures changes in heart rate and blood pressure in a patient while their hand is immersed in ice water for one minute.
[Scott] has tentatively dubbed his device The Pain Machine, but it does more than the typical cold pressor apparatus; it also delivers simulated pain relief in the form of warm water when the valves are reversed. In addition, the subject under testing can push a button when they’ve had enough. While his original plan used external sources of hot and cold water, [Scott] pulled a couple of Peltier coolers from some wine chillers for a more contained design.
The Pain Machine uses an Arduino ATMega 2560 to control gravity flow solenoids, collect temperature data, and send the data cloudward. A couple of 110V pumps circulate the water. [Scott] will open up the code once he has finished commenting it and fleshed it out with use cases. For now, you can check out his two-minute entry video after the break.
This project is an official entry to The Hackaday Prize that sadly didn’t make the quarterfinal selection. It’s still a great project, and worthy of a Hackaday post on its own.
Kinky! Just don’t squick the vanillas!
I thought the same thing. Next thing will be Arduino powered spanking “robots” and e-stim.
http://voiceinthecorner.com/2013/09/17/steampunk-spanking/
I’m imagining Chokebot from Archer.
http://en.wikipedia.org/wiki/Thermal_grill_illusion
This came to my mind also when I saw the title and pic. Thanks for the link, it’s been so long since I read about it, I couldn’t remember the name.
Oh man, that’s so cool. I’ve seen optical illusions and aural illusions, so I should have known there’d be tactile illusions, but I didn’t think of it.
The thermal grill illusion is very cool (pun intended), but not the same. The cold pressor is flushed with hot water, which doesn’t give contradictory sensation…. rather it gives relief.
