Simple LED Project To Spice Up Your Halloween Party
jackolantern
[Paul’s] project is a great example of how you can take a simple project and turn it into something more interesting. He built himself a jack-o-lantern with an Internet controlled RGB LED embedded inside.
[Paul] first wired up an RGB LED to a Raspberry Pi. He was sure to wire up each color using a 100ohm resistor to prevent the LED from burning out. The web interface was written in Python. The interface is pretty simple. It consists of three text fields. The user enters a value between 0 and 255 for each of the three LED colors. The program then lights up the LED accordingly.
[Paul] realized he would need a diffuser for the LED in order to really see the blended colors properly. Instead of using a common solution like a ping-pong ball, he opted to get festive and use a plastic jack-o-lantern. [Paul] removed the original incandescent bulb from the lantern and mounted the LED inside instead. The inside of the pumpkin is painted white, so it easily diffuses the light. The result is a jack-o-lantern that glows different colors as defined by his party guests. Be sure to check out the demonstration video below.
3 thoughts on “Simple LED Project To Spice Up Your Halloween Party
  1. Cool project.
    I thought about making one with a certain company logo on it, having it spinning round “spewing” green LED lit fog and screaming “Your momma fries Arduinos in Hell” .. but that would be too much work. :-)
Leave a Reply to Just HarryCancel reply
