War Gaming For Security Cred
Maybe you are an elite hax0r. But probably not. Maybe you feel like you should know more about how systems are compromised, and we’re all about that. You can’t keep the black hats out if you have no idea how they go about breaking in in the first place. That’s why war-gaming sites sprouted up in the first place. We find this one in particular to be delightfully engaging. OverTheWire’s Wargames teach you a little about security while the uninitiated also learn about simple concepts like SSH and, well… Linux!
On-the-job training is the best way to learn, and this is pretty close to it. Instead of providing an artificial avenue of learning the creators of OverTheWire have used the real thing to illustrate poor online security. You don’t “play the game” on an artificial web interface, you do it on legitimate platforms. The very first level (appropriately named Level 0) starts by figuring out how to connect to a system using Secure Shell (aka SSH). From there you’re prompted to use Linux command line tools to figure out where to go next.
Even veteran Linux/Security users should find this offering entertaining. The early stages are both quick and simple to navigate as an experienced admin while providing a welcoming learning platform for those who aren’t quite there yet. Work your way through a few different “servers” and before long your own knowledge will be tested. This isn’t a new platform, mentions of the site in Hackaday comments go back to 2010. But if you haven’t given it a try, Wargames is well worth adding to your weekend entertainment list.
[Thanks NightPhoenix]
11 thoughts on “War Gaming For Security Cred
  1. Sounds interesting enough.
    P.S I wonder why I can’t comment from the work system anymore….Guess it’s back to square one with having a lil relaxer at the J.O.B
  2. Is Bandit 22-23 broken? Looks like there hasn’t been an update since Jan 31st, suggesting cron hasn’t run this job in a while. Or did I miss something in the exercise?
  3. boJ9jbbUNNfktd78OOpsqOltutMc3MY1
    CV1DtqXWVFXTvM2F0k09SHz0YwRINYA9
    UmHadQclWmgdLOKQ3YNgjWxGoRMb5luK
    pIwrPrtPN36QITSp3EQaw936yaFoFgAB
    koReBOKuIDDepwhWk7jZC0RTdopnAYKh
    DXjZPULLxYr17uwoI01bNLQbtFemEgo7
    HKBPTKQnIay4Fw76bEy8PVxKEDQRKTzs
    cvX2JJa4CFALtqS87jk27qwqGhBM9plV
    UsvVyFSfZZWbi6wgC7dAFyFuR6jQQUhR
    truKLdjsbJ5g7yyJ2X2R0o3a5HQJFuLk
    IFukwKGsFW8MOq3IRFqrxE1hxTNEbUPR
    5Te8Y4drgCRfCx8ugdwuEX8KFC6k2EUu
  4. Hey, people, is there a file that is 1033 bytes in size in level5? Because I can’t find it even if I use
    du -b maybehere*/* | grep 1033
    1. “du -b” is how much space the actual file is using on the harddisk, which will probably be a multiple of 512.
      Try using something like “find . -type f -ls | grep 1033”
Leave a Reply to matt vennCancel reply
