[madis] has been working on time lapse rigs for a while now, and has gotten to the point where he has very specific requirements to fill that can’t be done with just any hardware. Recently, he was asked to take time lapse footage of a construction site and, due to the specifics of this project, used a Raspberry Pi and a DSLR camera to take high quality time lapse photography of a construction site during very specific times.
One of his earlier rigs involved using a GoPro, but he found that while the weatherproofing built into the camera was nice, the picture quality wasn’t very good and the GoPro had a wide-angle lens that wouldn’t suit him for this project. Luckily he had a DSLR sitting around, so he was able to wire it up to a Raspberry Pi and put it all into a weatherproof case.
Once the Pi was outfitted with a 3G modem, [madis] can log in and change the camera settings from anywhere. It’s normally set up to take a picture once every fifteen minutes, but ONLY during working hours. Presumably this saves a bunch of video editing later whereas a normal timelapse camera would require cutting out a bunch of nights and weekends.
The project is very well constructed as well, and [madis] goes into great detail on his project site about how he was able to build everything and configure the software, and even goes as far as to linking to the sites that helped him figure out how to do everything. If you’ve ever wanted to build a time lapse rig, this is probably the guide to follow. It might even be a good start for building a year-long time lapse video. If you want to take it a step further and add motion to it, check out this time lapse motion rig too!
Just curious, how do you keep something like this from being stolen if it is to stay on-site for weeks at a time?
Like anything else you don’t want stolen – make it very difficult to access. This one is mounted on a balcony on what looks to be at least the second floor. It can still walk off, but at least someone will have to work for it.
Josiah is right. I found a nice guy who let me use his balcony.
Nice build! You can get around the USB reset issue with a new build of gphoto2. v2.5.3 fixes the issue for future versions of your timelapse rig. See the instructions in the link below.
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=70049
Thanks, I’ll try it out!
