Hackaday Links: June 14, 2015
Hackaday Links Column Banner
You know we’re running this gigantic contest to build hardware and send someone to space, right? We’re doing community voting right now. If you’re on Hackaday.io, head over there and pick the best project. We’re giving away t-shirts and $1000 gift cards to people who vote. The drawing for this round is next Friday.
MicroPython is a pretty interesting development in the area of interpreted languages running on microcontrollers. It’s Python, the BASIC of the modern era, and now it’s being funded by the ESA. Great news, there’s going to be a port to SPARC, and it looks like MicroPython is going to be in a few satellites.
[EloquentlyMawkishBunny]’s calculator stopped working on the morning of his AP Physics test. It was the ribbon cable for the display. What did he do? He grabbed some magnet wire and made it work. If I’m reading this right, he did this the day of his AP test. Wow.
[Will] has made a name for himself by building roller coasters in his backyard. He’s also worked on the ProtoPalette, and now he’s building a hackerspace in Concord, California.
[Josh] needed to drill some very large holes with his mill. He decided a hole saw was the easiest way to do this, but his hole saw has a hex shank. He ended up chopping the shank of a hole saw extension, basically turning it into a hex to round adapter.
Did you know the Arduino IDE on Raspbian is stuck at version 1.0.5? The newest version is 1.6.4, and there’s useful stuff like autosave in the IDE now. Amazing. [CRImier] got the latest Arduino IDE working on the Raspberry Pi 2. Yes, there’s an issue up but if for some reason you’re programming Arduinos on the Pi, you should probably do this yourself.
Oooohhhh, case modding. The Intel NUC is a pretty interesting platform for case modding; it’s small, and I shouldn’t have to remind anyone of all the cool case mods that were created when the Mini-ITX format gained popularity in the early ‘aughts. [Femke] got herself an Intel NUC, made a case, and the results are amazing. How’d she get that metal bowl? Metal spinning. Very cool.
8 thoughts on “Hackaday Links: June 14, 2015
  1. Intel, after several years, finally fits a performance CPU into a small case and then someone comes along and plops it into something bigger. What’s next, a Pi in a Full ATX case?
    1. Right cause a case that’s about twice as big as the original, to house it and a custom water cooler is such a terrible thing. Should go check out some other case mods on Bit-tech, you might have an aneurysm with all the frivolous things they build.
  2. Great, I was finally able to vote without seeing the same projects over and over again. And i a pair was totally unacceptable and I refreshed the page, i got brand new projects to choose from.
    So, randomizer fixed I guess.
  3. Maybe I missed the point…but wasn’t the theme of “The HackADay Prize” to come up with systems that improve the environment? I doubt that some of the entries are into that venue. I did not enter my recent project into consideration given that theme.
Leave a Reply to DancesWithRobotsCancel reply
