Haven’t you heard? You can make your own 3D filament nowadays from plastic granules (10X cheaper than filament), or even by recycling old plastic! Except if you’re recycling plastic you will have to shred it first…
[David Watkins] came up with a different way of shredding plastic. Typically we’ve seen shrunken versions of giant metal shredders used to dice up plastic into granules that can be melted down and then extruded back into filament. These work with a series of sharp toothed gears that kind of look like a stack of circular saw blades put together inside of a housing.
But that can be rather pricey. [David’s] method is super cheap, and you can do it at home with minimal tools, and maybe $10 or less worth of parts?
Continue reading “A Different Kind Of Plastic Shredder For 3D Filament Making”
