[Chris Gregg] had a dream. He wanted to convert use a typewriter as a printer. Sure this has been done before, but [Chris] wanted to create his own version. He picked up a 60’s era Smith Corona electric typewriter, with the hopes of driving its key switches with a computer. You can imagine his surprise when he discovered the keys were not electric switches at all, but a complex mechanical system which triggered a clutch to strike the actual paper. Realizing this was not going to be a simple wiring job, [Chris] set the project aside, where it remained for several years.
A conversation with [Bruce Molay], a coworker at Tufts University reignited [Chris’] interest in project. [Bruce] suggested using solenoids to press the keys. [Chris] dove in, and quickly had 48 solenoids on hand. The first problem was mounting the solenoids on the keys. [Chris’] roommate happens to be [Derek Seabury], president of Artisan’s Asylum Hackerspace. [Derek] created an acrylic frame which holds the solenoids and fits directly over the typewriter’s keyboard. This meant that no modifications needed to be made to the typewriter itself. Simply lift off the solenoid array and you’re ready to rock like it’s 1965.
The next step was driving all those solenoids. For that, Chris worked with [Kate Wasynczuk], one of his students at Tufts. [Chris] designed a board using Texas Instruments TPIC6A595 shift registers. The TIPC “power logic” series work like regular 74 series logic, but have seriously beefy outputs. These chips can handle up to 50 volts and 1.5 amps pulsed output current – plenty for [Chris’] 24 volt solenoids. [Chris] taught himself schematic entry and PCB layout in Eagle. After only two tries, he had a working board from OSHPark.
An Arduino Uno converts serial over USB output to a bit stream ready to clock into the shift registers. On the computer side, [Chris] wrote up a basic CUPS driver which allows him to print from his Macbook. The perfect demo for this project turned out to be musical. Click past the break to see The Smith Corona perform “The Typewriter Symphony”, by Leroy Anderson. This may be the first time this particular piece of music has been performed with actual words being typed, rather than random keys.
Here’s a classic version of “The Typewriter Symphony”
I know a guy who did this for HP67 calculators in the 70’s. The little mag strip option for loading programs was not very reliable so he built a system of discrete logic and solenoids to push the keys. I wish I had some pictures. I think today he runs the IT department of the old library in Prague.
For the youngers who are not aware of it the last video is a remake of a scene from a movie starring Jerry Lewis. He was typing with this music in background.
Jerry Lewis on wikipedia: https://en.wikipedia.org/wiki/Jerry_Lewis
https://www.youtube.com/watch?v=ORu1peCxhvs
He’s doing the carriage returns the wrong direction. What kind of typewriter IS that?
This video has Jerry Lewis.
https://www.youtube.com/watch?v=Fxm0TN5WDQI
That scene isn’t the origin:
https://en.wikipedia.org/wiki/The_Typewriter
TL;DR the Jerry Lewis scene is from 1963 but the piece itself is from 1950.
Wondering why not design the electronics to drive the solenoids in an 8×8 matrix, MUX each 8 outputs to 3 inputs, for 3×3, which is 6 output bits, make the bell and shift key independently driven for 2 more output bits: 8 output bits total. The Arduino should be sufficiently fast to operate a typewriter directly.
There was a commercial product in the late 70’s or early 80’s that you could mount over the keyboard of a Selectric typewriter in order to use it as a letter quality printer.
Thanks for the lead on the TI TPIC parts .. These are perfect for one of my current projects.
