Hacklet 84 – Alarm Clocks
The stereotypical hardware hacker is a creature of the night. Some of us do our best work in the wee hours. The unfortunate side effect of this is that we have a hard time getting up in the morning. Sometimes life demands a hacker be up-and-at-em before noon though. In these cases, the only solution is an alarm clock. This week’s Hacklet features some of the best alarm clock projects on Hackaday.io!
mercyWe start with [hberg32] and Merciless Pi Alarm Clock. Merciless is a good name for this Raspberry Pi based clock. We have to say it’s quite snazzy with its laser cut case and large seven segment LED face. When the alarm goes off though, this Pi bites back.
Titanium drivers powered by a 20 watt amplifier will wake even the heaviest sleepers. If that’s not enough, [hberg32] added a bed shaker to vibrate you out of the sack. The snooze button only works 3 times, after that you can press all you want, the music will still play. As if that wasn’t enough, this clock even has a pressure sensor. If you get back in bed, the alarm starts up again. Truly fitting of the name “merciless”.
irss[Ceady] took the kinder, gentler route with Integrated Room Sunrise Simulator. This alarm clock simulates dawn, gently waking the user up. A Lutron Maestro series wireless dimmer allows the sunrise simulator to slowly increase the room’s light level over a period of 10 minutes, allowing [Ceady] to wake up silently.
The clock itself uses an ATmega168 for control. [Ceady] spent a considerable amount of time testing out different methods of creating a seven segment LED display. When casting with cornstarch and resin didn’t do the trick, he went to commercial LED diffuser film from Inventables. The film proved to be just what he was looking for.
chumby2Next up is [Spiros Papadimitriou] with DIY Chumby-lite. Taking inspiration from [Bunnie Huang] and the Chumby project, [Spiros] created a friendly alarm clock with a touchscreen LCD. Much like the Chumby, this clock packs a WiFi module.
In this case though, the WiFi module is an ESP8266, whose on-board Xtensa microcontroller runs the whole show. [Spiros] programmed his Sparkfun ESP8266 Thing in C++. To keep costs down, [Spiros] left out anything unnecessary – like a real-time clock module. The Chumby-lite uses NTP to stay regular. The reductions paid off – this clock can be built for around $13.00, not including the very nice 3D printed case.
1983[Wanderingmetalhead] takes us all way back to 1983 with his 7 Day Alarm Clock. 32 years ago, this was [wanderingmetalhead’s] first embedded system project. As the name implies, this clock stores a different wake time for each day of the week. Actual numeric entry sure beats the old “hold two buttons and watch the numbers spin” system.
This is an oldie. The system is based upon a Motorola (which became Freescale, and is now NXP) 6802 micro. The code was written in assembly and cross-assembled on an Apple II. A 3.58MHz colorburst crystal divided down to 60 Hz provides the time base. This setup wasn’t perfect, but good down to a about a minute a month. The whole project lived and worked in an old amplifier case, where it dutifully woke [wanderingmetalhead] each day for 17 years.
If you want to see more alarm clock projects, check out our new alarm clocks list! If I didn’t wake up early enough to catch your project, don’t be shy, just drop me a message on Hackaday.io. That’s it for this week’s Hacklet. As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
12 thoughts on “Hacklet 84 – Alarm Clocks
  1. A cow-orker has been interested in building an alarm clock that won’t go silently into the long goodnight. I’m going to point him to this hacklet.
  2. My friend’s 3-year-old has a great clock. It’s got a sun and stars on it. When it’s time to wake up, and not go back to bed cos it’s 5 in the morning, the sun lights up. So he knows when it’s time to get up and start running round like a nutter.
  3. “this clock can be built for around $13.00″ – How do you figure?
    Sparkfun ESP8266 – $15.95 (+shipping) [SparkFun]
    2.4” 320×240 TFT LCD – $20.49 (+shipping) [Amazon]
    500mAh 3.7v LiPo – 2.99 (+shipping) [all-battery.com]
    1. You can get the bits cheaper than Amazon, and particularly Sparkfun, prices. You have to deal with dodgy Chinese vendors you’ve never heard of though.
  4. Music? Music! Muahahaha! The Merciless Pi Alarm eschews music and rotates through a collection of sounds that are a little less subtle: cockpit warning tones! Forget sleeping in, you’ve got an engine fire to put out, pal. *WHOOP* *WHOOP* PULL UP!
    On a serious note, I’d be interested to hear what people think about ways to improve the bed sensor. The goal of the project was to create an alarm that can only be silenced one way: by getting up and staying up. I’m using pressure sensors from patient fall alarms currently but they are clearly marked as “expiring” after a year. Presumably this means there’s a chance that the foam will compress over time and lead to false positives. They are also sized for hospital beds so I have to use several to make sure there are no blind spots under a queen sized mattress.
    Another way I’d considered was using flexiforce sensors under the feet of the bed but I’m concerned that even if I use an adhesive to hold them in place they’ll be damaged over time as the bed slides around a bit on the hardwood floor.
    Henry (hberg32)
    1. Freescale sells some capacitive sensors that were designed for the automotive market to detect people in car seats and possibly make a size estimate on them for airbag control. They might be hackable into a bed occupancy sensor, but I don’t remember what the sensing distance was.
    2. There is another way: buy some cheap electronic bedroom scales, interface with them and put the entire bed on them. If the weight changes significantly, the alarm knows you’re up or back to bed.
Leave a Reply to wanderingmetalheadCancel reply
