Ever wanted to own your own Theremin but couldn’t justify dropping hundreds of dollars on one? Now you can build your own, or buy it for a quintuplet of Hamiltons. The Open.Theremin.UNO project has built up antenna-based oscillator control around the ubiquitous Arduino Uno board.
So what’s the Arduino in there for? This is a digital Theremin, but check out the video below and you’ll agree that it sounds amazing and has excellent response. The aluminum antennas used for volume and pitch are attached to the top portion of the shield but it sounds like they’re not included in the kit. Don’t fret, you can use a variety of materials for this purpose. On the bottom you need to connect a speaker cable, and also a ground wire if that cable’s not grounded.
As the name implies, this is Open Hardware and we’re quite happy with the documentation on their site and the BOM (found on the GitHub repo). This design was shown off back in 2013 hiding in a pack of cigarettes. If you don’t want to build your own they’re selling kits on their site for 48 Euro delivered, or on Tindie for $55.
Okay, we’ve screwed this up so many times that we’re going to try to get it right here: the Theremin was not heard in the opening of Star Trek the original series, or in the opening of Doctor Who. It wasn’t featured in “Good Vibrations” either. As far as we can tell, it’s not used for anything in pop culture at all… but recognizing the sound and knowing what one is remains core geek knowledge.
If you want a Theremin to play using your entire body you need the Theremin Terpsitone.
[via Open Electronics]
The theremin is cool, but I actually like his “making-of” video as much or more. Pick-n-place from a scavenged scanner? Way cool, dude.
https://www.youtube.com/watch?v=i0ZT4y3DYrY
Yea, his homebuilt pick-and-place really deserves it’s own post on HAD.
+1
A DIY pick and place that actually works…
Wow! Thanks for sharing this, crazy impressive!
Agreed
This video needs to be on front page with the article!!! Very inspiring for the home hacker :)
Thanks!
Subscribed, and the pick and places machine added to the huge bucket list, maybe with a delta 3d printer instead of scanner.
midsomer murders has one in its opening theme
https://en.wikipedia.org/wiki/Midsomer_Murders#Soundtracks
Need more P&P! Thereasonminitheraminarethere!
At least 272 people in Japan can play a melody on a Theremin. They Guinness-ed their lot into a heavenly rendition of Amazing Grace.
In tune, awesome. Tuning up, like being in a bird and seal park.
I like the whole idea though, especially the C/V out.
The lady in the video looks like she’s trying to play a violin with her right hand. I guess if she’s left handed that would make sense, but I know I would prefer to have the pitch antenna on my left hand.
I think you could just turn it around
I was surprised to learn that the theramin also wasn’t used in Louis and Bebe Barron’s incredible soundtrack for “Forbidden Planet” (although the Barrons did use theramins in other music).
Yeah, production on that was really interesting. I understand the Barrons had circuitry that was terribly overloaded to get some of their sounds, so much so that it would occasionally burn out. They’d capture that audio on tape tracks because it was seldom reproducible.
And the irony of that classic music score was that the musicians union, which the Barrons were not part of, wouldn’t allow the score to be called “music”, hence the credit for them reads “Electronic Tonalities by Louis and Bebe Barron”.
It was also used on the soundtrack for The Day the Earth Stood Still.
the John spence blues explosion uses it. And gives a very nice demonstration/ explanation in this video.
https://www.youtube.com/watch?v=vyF_UN8g9f0
https://youtu.be/pSzTPGlNa5U
The hardest thing to play with a theremin is doing it without the vibrato, because you have to hit every note right on the first try.
The tuning of a theremin isn’t stable, so you’re always playing by ear. If you tend to get sweaty hands from stress, the tuning can change from the start to the finish of the piece you’re performing even if you were nailed to a board to keep you otherwise steady, because the conductivity of your skin changes.
I keep wondering if you could do this with motion/position sensors instead of antennae. Would they be sensitive enough to pick up all the subtle motions and hand orientations that the radio system can?
That video *almost* sounds like music.
A cover of “Still Alive” with Dorit Chrysler on a Moog theremin is here:
https://www.youtube.com/watch?v=RSsstXfcRWw
Moog’s site claims that their theremins have “…reliable spacing between notes…”; although I’m no expert, that might make their theremins easier to master.
That music video was a huge dissapointment.
Anyways, I guess you can build a sort of auto-tune to a theremin.
Those antennas are parts of resonant circuits whose resonant frequencies are disturbed by the proximity of grounded objects.
To implement reliable spacing between notes, those resonant circuits cannot produce or control the sound directly. There must be something between the sound producing oscillator and amplifier and the resonant circuits whose function is to scale those circuits outputs.
If that midstage something should produce voltages, that would turn the antenna fed resonant circuits into controllers that would fit quite well Moog’s classic designs that use voltage controlled oscillators and voltage controlled amplifiers.
Again, I’m no expert.
DAX:
My goal was to show that the theremin can be played well by a skilled musician and that it can be part of an ensemble that plays together and in tune with each other. You have my apologies if you didn’t like that band’s performance.
Leon Theremin playing his own instrument
https://www.youtube.com/watch?v=q1hBeuak0oQ
Jimmy Page Plays Theremin and Violin Bow solo. 17th July 1977
https://www.youtube.com/watch?v=QtoVZ4eObg8
Jimmy Page plays the Theremin
https://www.youtube.com/watch?v=4kujH0ScAi0
Good Vibrations – Theremin intro
https://www.youtube.com/watch?v=CelV7EbuV-A
Trekkie plays Star Trek theme on Theremin
https://www.youtube.com/watch?v=V0zQHNmz0gU
Without a demo with someone who can play Theremin at lest a little bit on this thing, I would not believe that their circuit is acceptable. Unless the field sensitivity in the pitch antenna is somewhat linear, a Theremin is useless.
Unless the field sensitivity in the pitch antenna is somewhat linear? Ever look at a fretboard? All the string family has a non-linear pitch curve. In the above video of Good Vibrations I see a “linear” slide wire on the box. It is a Tannerin of not much more than an octave. The first of the wire on a drum-knob on a pot controllers was the Ondes Martinot dating from the same era as the theremin. Interesting that he plays it right handed, as I do with a slide guitar with self sustaining tech built into the instrument. The bar has the volume control built into it for one handed control!
Only the drum-knob on a pot design can be made linear and is placed above or below a keyboard for a familiar feel.
Remember though, there are no frets or keys in the human voice.
Captain Beefheart & The Magic Band track ‘Electricity’ off first album ‘Safe as Milk’ has theremin played on it. Listen to it – it is life changing!
