540 LEDs On A Geodesic Sphere
[burgerga] loves attending Music Festivals. He’s also a MechE who loves his LED’s. He figured he needed to put it all together and do something insane, so he build a huge, 15″ geodesic sphere containing 540 WS2812B addressable LED’s. He calls it the SOL CRUSHER. It sips 150W when all LED’s are at full intensity, making it very, very, bright.
As with most WS2812B based projects, this one too is fairly straightforward, electrically. It’s controlled by four Teensy 3.2 boards mounted on Octo WS2811 adapter boards. Four 10,000 mAh 22.2V LiPo batteries provide power, which is routed through a 5V, 30Amp heatsinked DC-DC converter. To protect his LiPo batteries from over discharge, he built four voltage monitoring modules. Each had a TC54 voltage detector and an N-channel MOSFET which switches off the LiPo before its voltage dips below 3V. He bundled in a fuse and an indicator, and put each one in a neat 3D printed enclosure.
The mechanical design is pretty polished. Each of the 180 basic modules is a triangular PCB with three WS2812B’s, filter capacitors, and heavy copper pours for power connections. The PCB’s are assembled in panels of six and five units each, which are then put together in two hemispheres to form the whole sphere. His first round of six prototypes set him back as he made a mistake in the LED footprint. But it still let him check out the assembly and power connections. For mechanical support, he designed an internal skeleton that could be 3D printed. There’s a mounting frame for each of the PCB panels and a two piece central sphere. Fibreglass rods connect the central sphere to each of the PCB panels. This lets the whole assembly be split in to two halves easily.
It took him over six months and lots of cash to complete the project. But the assembly is all done now and electrically tested. Next up, he’s working on software to add animations. He’s received suggestions to add sensors such as microphones and accelerometers via comments on Reddit. If you’d like to help him by contributing animation suggestions, he’s setup a Readme document on Dropbox, and a Submission form. Checkout the SolCrusher website for more information.
Thanks [Vinny Cordeiro], for letting us know about this build.
6 thoughts on “540 LEDs On A Geodesic Sphere
  1. The build log and the video imply that he is only using one teensy with four control lines to the LEDs, as well as only using one battery at a time.
  2. The most important thing that I learned from this is not to use ‘imgur’ for your build log.
    It’s very difficult to scroll through with my device, and is the first time that I’ve had to disable the ‘power-save mode’ in order to continue.
    The build itself is quite impressive! That is a lot of PCBs and they came out very nicely. A whole bunch of 3D printed parts for the custom frame.
    This monster looks awesome. :)
  3. Adding an accelerometer to get some gesture based interaction would be the next step in my book. Looks fantastic.
  4. I think it would be nice with some form of diffuser, I prefer not to have bright lights coming from point sources in my field of view.
Leave a Reply to ShannonCancel reply
