One of the first electronics projects for the aspiring hobbyist is wiring a sensor of some sort to a microcontroller, and then doing something useful with the new information. [Brock] has taken this type of gateway project and turned it into a way to get his students involved and familiar with electronics. His take on an air quality meter accomplishes both of these goals, and hopefully helps turn all of his students into the next generation of hackers.
The bill of materials is pretty straightforward. Instead of the go-to Arduino, [Brock] has gone with a Particle Photon which has the added benefits of various wireless connectivity options. The air quality sensor is a Shinyei PP42ns which interfaces easily with the Photon. The only thing that might be out of reach of most public high schools (at least in the United States) is the 3D-printed enclosure, although if you have access to one, [Brock] put the files on the project page so anyone can use them.
Of course, we’re big fans of projects that get students involved in anything beyond standardized tests, and this project goes a long way towards teaching students more than how to pass a test. There are many videos and instructions on the project page if you want to try this on your own, but if the cost for the materials is the only thing scaring you off from doing this in your own classroom there are a few other options. You could use ATtiny chips, or try a different style of sensor, or maybe just try out a different project altogether.
Getting meaningful data from this sensor is not straightforward,
if you are more interested in the sensor itself read this:
http://irq5.io/2013/07/24/testing-the-shinyei-ppd42ns/
Agreed -the sensor can be frustrating to get a good reading until I read https://indiaairquality.com/2014/12/14/measuring-the-pickle-jr-a-modified-ppd42-with-an-attached-fan/
This is why I attached a resistor to PIN5. It makes it much more sensitive and accurate at normal indoor levels.
The Particle Photon is also ridiculously overpriced.
You can also checkout this monitor which is open source too: http://hackaday.com/2015/08/09/watch-those-vocs-open-source-air-quality-monitor/
