Honey, They Shrunk The Transistor
Silicon transistors keep shrinking (current state of the art is about 20 nanometers). However–in theory–once the gate goes to 5 nanometers, the electrons tunnel through the channel making it impossible to turn the transistor off. Berkeley researchers have used a different material to produce a transistor with a 1-nanometer gate. For point of reference, a human hair is about 50,000 nanometers thick.
The secret is to switch away from silicon in favor of another semiconductor. The team’s choice? Molybdenum disulfide. Never heard of it? You can buy it at any auto parts store since it is a common lubricant. Electrons have more effective mass as they travel through molybdenum disulfide than silicon. For a larger transistor, that’s not a good thing, but for a small transistor, it prevents the electron tunneling problem.
Creating a 1-nanometer structure is a challenge all by itself. The new transistor uses a 1-nanometer carbon nanotube as the gate. The transistors will need work to be commercially producible.
We didn’t know that a common lubricant is a semiconductor with similar properties to silicon. We looked at its use in thin semiconductors with graphene. We even talked about its use as a lubricant before. We just didn’t put two and two together. That’s the kind of thing that gives us ideas.
22 thoughts on “Honey, They Shrunk The Transistor
        1. Okay we’re getting warm with the graphene structure…www.nature.com/nnano/journal/v7/n11/full/nnano.2012.193.html and…www.nature.com/nnano/journal/v8/n7/full/nnano.2013.100.html
    1. What’s not fun about about this title? To me it feels like headlines we’ve used since the beginning. There’s nothing sensational about it… legitimately they made transistors smaller that was though possible/practical.
      Buzzfeed-esque would be: “Five Shocking Tricks Scientists Used to Shrink Your Microchips”
        1. Wait until the mailman breaks some displays he orders by tossing them over the fence, then we’ll have one like Szczys Sick as Sixty Pixies over Nixies Frisbee…
          Maybe he prowls the Register daily and C&Ps the good ones…
  1. Well, if you read the paper you´d realise that only the carbon nanotubes are 1nm thick. The whole transistor is bigger (even than traditional designs). Its still a good experiment and a good paper with a lot of potential, but no 1nm transistor.
  2. It is 3.9 nanometer they made it 1 nanometer smaller than it was said it is possible. The whole thing is about 20 000 nanometer long.
  3. Current state of the art is 16nm, not 20nm, even for commercial designs. 10nm has been in the works for a bit.
  4. Well, manufacturing will be a severe problem – can’t be done with standard semi equipment, as RIE etching etc. Perhaps you’ll have to print or use precursor and Ion beam technologies. Don’t see this as a product, soon.
  5. The problem with any mass produced transistor is replication- even if this works its going to need serious effort to guarantee that all the components work. One idea I did have is to replicate each component twice, but this just adds even more expense.
Leave a Reply to QualigatorCancel reply
